06-22-2010, 01:15 AM | #1 |
roof rack installation
does anyone have experience installing a roof rack. Question is; does the "screw plug" install from the top down, or from the inside of the cab to out. sorry for the bad pics. the brass screw inside is flush with the base of the "non flange" end. My thought process is from the top in, when you screw down the rack "legs" the brass plug will "bunch up" the rubber like a gyproc wall plug. The instructions pic suggests differently.
thx, Al.
1972 GMC Sierra 1972 GMC Super Custom Suburban |
06-22-2010, 10:02 PM | #2 | |
Re: roof rack installation
You are most correct, oh wise one!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-23-2010, 12:52 AM | #3 |
LOL, kinda figured you would be the one to reply sooner or later. thx. I also found out the the package was missing 5 screws that go through the legs in the rubber plugs. Do you know where to find these? 1 1/4 x 1/4 coarse thread. small ovaled head.
thx again, Al.
06-23-2010, 10:46 AM | #4 | |
R/
07-02-2010, 02:00 AM | #5 |
can you explain in dummy english just how these racks mount on top of the burb. I have one that I need to install. what are those "plugs" you have in the pics????
07-08-2010, 09:53 AM | #6 |
The "plugs" are more commonly known as well-nuts. They go through about a 1/2" hole in the roof and have a threaded brass insert at the bottom for a 1/4-20 screw. When you tighten it down it collapses the well-nut tight around the sheet metal providing a seal and an anchor.
01-15-2011, 12:47 AM | #7 |
how much is a roof rack? im planning to install a roof rack this week before we go on vacation this coming weekend... thanks
_______________________ OEM Bed rails, OEM Brush guard, Magnaflow 22" with Gibson pipes, PRG Mini-lift, Cooper Discoverer S/T 35x12.50x17, Lund hood protector, Go Rhino, Ventshade in-channel window visors, Bushwacker Extenda-flares, front window tint. |
01-15-2011, 03:33 AM | #8 |
The roof racks for the 67-72 with the stainless strips are hard to come by. And i have found that the bolts at the hardware store are a little different but will work. I was wanting to know who manifactured these racks?
69 stepside, 1/2ton, 4X4, 350/350/205 |
01-21-2011, 04:15 AM | #9 |
I'd like to get 1 also
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
