Old 06-22-2010, 06:19 PM   #1
Cali2Texas
need some help
ok guys. i have problem. i smell gas when i stop or when i just start the truck. what is cause of this and does any have pictures Interior of 83. i am trying to replace everything with original parts.
Cali2Texas is offline   Reply With Quote
Old 06-22-2010, 06:29 PM   #2
Jonboy
Slots go on anything!
Re: need some help
I would check the fuel lines on top of the tank. They deteriorate over time, and that could be the cause of your smell. This is assuming that you have checked for fuel leaks under the hood first.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-22-2010, 06:43 PM   #3
tucsonjwt
Re: need some help
I concur with Jonboyl. I just replaced the sending units on both tanks and the rubber hoses between the tank and hardlines (3 different sizes of short lengths) were all rotted. I used new hose and clamps. It is a PITA to get to them - but I have a dump box conversion so I just lifted the box to get at them - otherwise, I think you have to drop the tanks.
Of course, you could be leaking gas under the hood - like at the carburetor - which happens with my stock Quadrajet. However, replacing the soft lines at the tanks fixed most of the problem for me. Good Luck.
tucsonjwt is offline   Reply With Quote
Old 06-22-2010, 11:52 PM   #4
po_bird
po_bird's Avatar
Re: need some help
I would think that you have a fuel leak or you carb is flooding. Not sure what type of carb you have, but holley carbs tend to leak out of the throttle shaft. The charcoal canister can cause strong gas fumes as well.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 06-23-2010, 10:02 AM   #5
Cali2Texas
Re: need some help
po bird
i have new 600 edelbrock carb, this will be my project for this weekend. the smell of gas is very strong. i made a lady roll up his windows up this morning...lol
thanks everyone.
