Old 06-26-2010, 08:33 PM   #1
Fraser Beatty
Fraser Beatty's Avatar
Truck Won't Start, But Turns Over- Ideas???
My current truck (80 GMC C25) was running/driving great the day before yesterday. It sat all day yesterday. When I went to fire it up today, I can't get it to start. It'll turn over strongly and as it should, but will not start. About every 20 revolutions of the engine or so, it will pop and sound as if it is going to start, but then promptly dies. Any ideas on what could be causing this, or list of things I should check?
Thanks for any help!
1961 GMC 930- SOLD
1979 GMC C35 Single Wheel Camper Special- SOLD
1980 GMC C25 Camper Special- SOLD
1983 Chevrolet C10- SOLD
1983 Chevrolet Camaro- SOLD
1985 GMC C1500 (Dad's truck)
1985 GMC C3500 Crew Cab Dually- TRADED FOR 61 GMC
1997 Dodge Ram 1500 V6 Shortbox- Daily Driver
Fraser Beatty is offline   Reply With Quote
Old 06-26-2010, 08:40 PM   #2
jimmy3fan
jimmy3fan's Avatar
Re: Truck Won't Start, But Turns Over- Ideas???
Sounds like an ignition module or pick up coil.
jimmy3fan is offline   Reply With Quote
Old 06-26-2010, 10:41 PM   #3
joe231
joe231's Avatar
Ignition coil or module
CHEVY ONLY
Old 06-26-2010, 11:13 PM   #4
55chevy
Car Truck Bike Nut
55chevy's Avatar
Fuel or spark, pull a spark plug wire, put a plug in it, ground it to the engine, turn it over to see if you have spark. If you have spark, then a fuel problem. If no spark, then coil or module. Replace the coil, if that's not it then you can usually return the coil. I tracked down an engine to the module this way, got a cheap one from the junkyard and that took care of it.
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 06-26-2010, 11:15 PM   #5
craazy22
craazy22's Avatar
Sometimes when you try to start and it pops it can be the timing
81 chevy stepside 6.0/t56 swap in progress....
81 chevy silverado k5 2wd 350 tpi and 700r4.. SOLD
07 chevy colorado "work truck" SOLD
02 chevy silverado z71 off road package
craazy22 is offline   Reply With Quote
Old 06-29-2010, 08:08 PM   #6
Fraser Beatty
I checked just now, and the truck appears to have spark. Pulled 3 plug wires, and all produced spark when held against the engine block. Truck also seems to be getting fuel, and the choke is working ok.
When I first found the problem, the truck would fire for a couple revolutions about every 20 revolutions I turned it over, but it has since quit doing even that. Would the timing just go over night like that? It was running perfect one day, and the next, nothing. Any more advice would be greatly appreciated!
1961 GMC 930- SOLD
Old 06-29-2010, 08:18 PM   #7
Sillyoldman
#16876
Sillyoldman's Avatar
Splash a little gas down the carb and try. Maybe a fuel pump issue? Also pull the distributer cap. Sometimes the condensor wire will rub on the spindle and in time wear through and short out. Shot in the dark but easy to check.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-29-2010, 08:24 PM   #8
73chevyman
73chevyman's Avatar
sounds like theres trash in the carb or the feul filter cloged.... change feul filter
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 06-29-2010, 08:49 PM   #9
tucsonjwt
Two thoughts:
1) Choke valve. Press the accelerator all the way to the floor to set the choke when the engine is cold. Press the accelerator all the way to the floor again and turn the ignition to start. See if that makes any difference. Also, the choke may look completely closed but may not be. After pressing the accelerator all the way to the floor when the engine is cold -stop - pop the hood - remove the air cleaner-pull back on the throttle linkage all the way with your right hand and press down on the choke valve in the carburetor with the other hand. Release the throttle but keep your hand on the choke valve to make sure is closes all the way. Dirt, stuck linkage, worn choke valve, etc. can leave the choke open just a tiny bit and prevent starting.
2) Do you drive your truck daily on the highway? If not, carbon builds up and causes trouble. If you don't drive it but once a week or so - varnish will build up and kill your carburetor. Spray carb cleaner down the carburetor once you get it started and keep the RPMs high while you continue to spray. Use up a whole can - having an assistant rev the throttle under the hood while you spray cleaner down the carb and all around the linkage helps. If the problem is the choke - convert to a manual choke so you have control over it - not an unreliable thermo coil.
tucsonjwt is offline   Reply With Quote
Old 06-29-2010, 09:47 PM   #10
Fraser Beatty
Sillyoldman/73chevyman: Pouring gas down the carb appears to do nothing. I seem to be getting lots of spark though.
tucsonjwt: Whenever one of these trucks won't start, the first thing I do is put the accelerator all the way to the floor. I tried it again though since you mentioned it, no luck though. The choke valve is free and can close all the way. I don't drive the truck at all, just start it up and run it up and down the laneway every other day or so.
1961 GMC 930- SOLD
Old 06-29-2010, 10:34 PM   #11
Slofarmtruck
This may sound dumb but check to make sure your distributor is not loose and spun on you.
Slofarmtruck is offline   Reply With Quote
Old 06-29-2010, 11:56 PM   #12
tucsonjwt
If you don't drive the truck at all - I think you are closing in on the problem.
You must have a ton of varnish and carbon in that carburetor. These old carbureted vehicles need to be brought up to operating temperature regularly and run for a while or you will always have trouble with the carb. Do you have access to another known good carb you can temporarily swap out? It doesn't take long to do, and you would answer the carb question quickly.
On the square bodies I have owned, all of the no start when cold issues have been related to choke or carb. All of the performance issues (missing, no start when hot, etc.) have been electrical issues.
One other thing - try a shot of starting fluid (ether) to get the truck started. If it doesn't work you can always use it next month when winter starts in the great white north.
Old 07-01-2010, 07:49 PM   #13
Fraser Beatty
I checked distributor, everything seemed to be ok there. Starting fluid didn't help at all. I think I have another carb kicking around somewhere, will try it out and let you know what happens.
1961 GMC 930- SOLD
Old 07-01-2010, 09:42 PM   #14
tucsonjwt
OK - you got a can of "winter fuel" ready to go.
Of course, I did say "known good carb", not one that is carboned or varnished up. I would take a comparable one off of your running fleet or a buddy's truck (temporarily), so you know you have a good runner. Should be no harm to the loaner carb, and shouldn't put the loaner vehicle out of service for more than 1 hour max. I think that will address the fuel delivery issue - assuming fuel pressure after the fuel pump is good. Of course, I am talking comparable intake/linkage setup - like both spreadbore intakes, etc., otherwise the bottom of the carbs won't bolt up - throttle body gaskets, etc., and you won't start it anyway. Good luck.
Old 07-02-2010, 10:22 PM   #15
Fraser Beatty
We had a few cans of ether/liquifire kicking around for use on the tractors in the winter, I checked and I have 2 known good carbs available, will try and swap one on tomorrow and let you know how that goes.
1961 GMC 930- SOLD
Old 07-02-2010, 11:31 PM   #16
tucsonjwt
After you swap the carb out, you will probably have to drop a little gas down the top of the carb if it does not start up after a few crank attempts, so don't give up if it does not start right up.
Old 07-15-2010, 07:31 PM   #17
Fraser Beatty
Finally got around to swapping a known to be good carb on. NO LUCK! Still has the same symptoms, even with gas down the carb. Turns over strong, but doesn't want to start.
1961 GMC 930- SOLD
Old 07-15-2010, 07:48 PM   #18
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
The best thing I can recommend is to do the following.
Go to the engine section and check the sticky about finding and setting tdc and timing.
Check fuel level in the carburetor and whether you have adequate fuel coming from the accelerator pump nozzels. Check to see if the choke is setting properly and that the vacuum pulloff is working. Check fuel pump output and pressure. Check compression.
Make sure all the valves are moving ie check for flat cam lobes.
You might check to see if the distributor gear is loose, I'm not sure what the consequences of the cotter pin being sheared off would be?
God Bless, Terry :-)
77 350 Shorty Wide is offline   Reply With Quote
Old 07-15-2010, 10:32 PM   #19
urone
does you truck have a ESC my 1986 Blazer acted the same way and after changing module 5 times it turned out to be the ESC (electronic spark control) located behind the glove box. I don't if your truck has thai item
urone is offline   Reply With Quote
