Old 06-30-2010, 05:50 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Cool 86 front end rebuild
okay im doing a lift on my 2wd.
i have ordered a set of 88-98 4" lift spindles
i need to order a set of 3/4 ton lower control arms and im considering RockAuto but i wanted to be sure that i am ordering the right ones
since i want 3/4 ton lower control arms i selected an 86 C30 pickup as the vehicle in the catolog search, is this right or is this 1 ton?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 06-30-2010, 05:56 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: 86 front end rebuild
10 = 1/2 ton
20 = 3/4 ton
30 = 1 ton
For Chevrolet
C = 2 wheel drive (R for 87 truck)
K = 4 wheel drive (V for 87 truck)
RandyP is offline   Reply With Quote
Old 06-30-2010, 06:17 PM   #3
bucannon
Salty Sailor
bucannon's Avatar
okay thanks, lower control arms are ordered now too.
but has anybody else done this spindle swap before on this forum? (i know some people have) what else will i need to buy?
Savannah, Georgia
Old 06-30-2010, 07:09 PM   #4
RandyP
RandyP's Avatar
I did not know you could do this sort of swap myself. I'll be watching to see the outcome. Wish you luck and hope it's what you want. I'm all about raising a truck some.
Old 06-30-2010, 08:35 PM   #5
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: 86 front end rebuild
Yea it is possible, ive been researching all the different ways to lift the 73-87 2wd trucks because i love to have big mud tires and im tired of my tires rubbing at every bump i hit ha ha
and as soon as i found out my spindle was damaged after my left front bearing went out i had the excuse i needed to JACK IT UP!!!!!!!!!!!!!!!!!!!
you can use an 88-98 spindle on a 73-87 truck if you use the 3/4 ton lower control arm as it accepts the larger balljoint.
Savannah, Georgia
Old 07-05-2010, 11:31 AM   #6
bitchin85
bitchin85's Avatar
i gotta see hpw this turns out! ive been wanting to lift my 2wd but didnt want a huge bodylift..
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
2wd lift, 73-87 chevy truck, bucannon
