07-01-2010, 07:47 PM | #1 |
Active Member
1968 Big Block trucks
Any of you guys out there that have factory original Big Block trucks, please tell me if your truck had the exhaust heat sheild under the hood, the one that mounts down low on the pass side fire wall/floor board.
My truck is an original 1968 BB truck and it does not have it, did the first year "1968" bb trucks have this, or did it come on the later years only. Last edited by burb71; 07-01-2010 at 07:47 PM. |
07-01-2010, 09:05 PM | #2 | |
Re: 1968 Big Block trucks
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-01-2010, 09:06 PM | #3 |
I have a 70 GMC 402 BB original and I dont remember seeing one on my rig when I did the tear down. But the PO may have removed it.
70 GMC LWB Fleetside, 402BB, TH400 90K original only cost $50. |
07-01-2010, 09:29 PM | #4 |
I have a 70 bbc with heat shield there. Thanks Jason
07-01-2010, 10:01 PM | #5 |
My 70cst is a numbers matching BB and it doesn't have a heat shield. Although it might have been removed at some time in its former life.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 07-01-2010 at 10:01 PM. |
07-02-2010, 03:10 AM | #6 | |
Active Member
Hey, thanks you guys for the quick response. But now, If the heat sheild had been removed by someone, there will still be the 2 holes there where it had been mounted or at lest the 2 screws in the holes. My truck does not even have the holes, I think that 70cst may be right about it starting in 1971. Both my 1971 & my 1972 BB trucks had the sheilds Last edited by burb71; 07-02-2010 at 03:11 AM. |
07-02-2010, 03:17 AM | #7 |
Active Member
07-02-2010, 03:26 AM | #8 |
i thought big blocks didnt come out til like 71 or 72
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-02-2010, 09:41 AM | #9 | ||
"I ain't nobody, dork."
The 396 was earlier than 71-72.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-02-2010, 10:26 AM | #10 |
My 70 has a 402.
07-02-2010, 11:00 AM | #11 |
both my 68 big blocks don't have the shield. My GMC had headers when I bought it from the PO. My chevy had a small block where the big block previously was.
07-02-2010, 11:14 AM | #12 |
I think in 69 one could get the 396. Then is 70 it went from a 396 to a 402. I think.
07-02-2010, 11:55 AM | #13 |
Active Member
The first year for Big Blocks in our trucks was 1968 the engine was the 396,
in 1970 it was bored out to 402. 1973 was the first year for the 454 in light duty trucks |
07-02-2010, 11:55 AM | #14 |
My 70 has dimpls for drilling holes in the correct spot.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
07-02-2010, 12:11 PM | #15 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
07-02-2010, 01:06 PM | #16 |
Spot on...I wasn't sure if it was 68 or 69.
07-02-2010, 01:25 PM | #17 | |
Active Member
Thanks again john, I have one I just dont want to install it if it's not factory correct for 1968. I want my restoration as close to original as can be. |
07-02-2010, 01:42 PM | #18 |
That's the direction that I am going except I did up grade to disc brakes for driveability issues. I added am/fm which wasn't avaliable until 71 I believe. I also added a tillt. Otherwise it is fairly close to stock. Oh yes...I changed the shoes to TT II's.
07-02-2010, 03:26 PM | #19 |
Burb 71,
Yes this is a complete original 70 bbc swb truck, still original paint truck. When i bought it, it was last tagged in 81. |
07-02-2010, 03:44 PM | #20 |
wow
