Old 07-07-2010, 02:19 AM   #1
DBLSPRT68
DBLSPRT68's Avatar
Might be picking up an 89 Sub 2500
Hey all, I ran across a find. I can trade my car trailer for a nice running 89 Suburban 2500 with the 454tbi and th400. It has had only two owners, with the first ordering it for towing a camper. Interior is excellent, but outside has some damage. a/c is cold. He's wanting $1800.00 for it, which is what I wanted for my car trailer. I'm pretty sure we are going to swap. So, is there any known problems with the 454 tbi or the 89 Suburban that I should know about?? Any help would be appreciated No pics right now, but grill and bezels are busted, bumper is bent, qtr panel is bent some. I don't care about the qtr. Will fix the grill. This will be to pull our 27 ft RV camper for now, and maybe later a driveline swap to my truck. Thanks. David
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 07-07-2010, 10:59 AM   #2
blakeduren
Re: Might be picking up an 89 Sub 2500
Sounds like a good deal.
No real "known problems" with that year and driveline combo that I know of.
blakeduren is offline   Reply With Quote
Old 07-08-2010, 10:18 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
from trailering make sure to check the rearend well/good for rear end noise,leaks etc.unknown to me PO had rearend welded up .it lasted ok for a while but got worse after trailering
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-08-2010, 10:57 AM   #4
blakeduren
Well, since it is a 3/4 ton and has the BBC in it....it will have the infamous full floating 14 bolt.
You might check the factory codes or just open the diff cover so see what gears you have.
I ended up with 3.21 gears, so it works for all the highway miles mine gets, but with a 27 foot camper, you might want the 3.73, 4.10 or 4.56's to get going up those hills!
Here are the factory papers: page 3 has the towing info
http://coloradok5.com/brochures/1989/
Old 07-08-2010, 10:29 PM   #5
DBLSPRT68
DBLSPRT68's Avatar
An 89 would have a SF 14 bolt correct? I have one makeing noise and leaking in my 83 (was swapped in before). I did pick up a real 14 bolt FF from a 79. I'm going to get that gone thru and it'll go in my truck As soon as I get it home, I'll be looking for codes and such to figure out what ratio it has. We do have some hills around here, so I hope they have some lower numbers; but not 4.56's! I hope to get 10 mpg's Thanks for the info, I'll check it out. Going to pick it up Saturday if the test drive is OK. David
Old 07-09-2010, 12:20 AM   #6
blakeduren
If you look at page 4 of that link...you will see that the 454's always got the FF axle.
My 83 3/4 ton is the same way, SBC got the SF and the BBC got the FF.
Old 07-09-2010, 12:49 AM   #7
DBLSPRT68
DBLSPRT68's Avatar
You are correct! I looked at that after I printed it off. Man, this deal is too good to be true!!! I hope all goes well and it comes home with me this Saturday. It's a two hour drive home, so first real drive; WILL BE A FIRST REAL DRIVE in a year. Only known problems are some body, grill damage and worn tires. Wish me luck! Thanks guys for the info. Looks like I might be joining the ranks here as well
Old 07-11-2010, 11:08 PM   #8
DBLSPRT68
DBLSPRT68's Avatar
He she is guys....Yes it's been beat up. Made the 2 hour trip home with NO issues First pics is from Sat after getting back home. Next are from today after a wash and interior clean. I swapped my old school slots and all terrains. I don't have a rear bumper right now, will get one ASAP. All the front end stuff I need is on my truck ATM. Don't worry about my poor truck, I'm picking up another one tomorrow Enjoy
Old 07-12-2010, 12:30 AM   #9
Chevy623
Chevy623's Avatar
Looks great with the slots and a/t's on it.
I wouldn't even mind those dents if those running boards would disapear though lol.
Jesse.
Chevy623 is offline   Reply With Quote
Old 07-12-2010, 06:45 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
Nice catch,sounds nice and solid,dents can be fixed
John
Old 07-12-2010, 08:53 AM   #11
justpball
justpball's Avatar
nice find! the slots look great!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 07-12-2010, 10:34 AM   #12
Davidmichael
Davidmichael's Avatar
nice score
Davidmichael is offline   Reply With Quote
Old 07-13-2010, 10:36 AM   #13
blakeduren
Nice wheels and tires!
I would:
Ditch the boards.
Fix the grill.
Get a rear bumper.
Tune it up and drive it like I stole it.
What are your plans? Fixing the body or just using it as a tow rig?
Old 07-13-2010, 11:51 AM   #14
Davidmichael
agreed. ditch the boards, buy a grill and w/e front end pieces you need, pull the dents in the rear and get a bumper/roll pan and drive the snot out of it.
After a while you get bored slam it. or do your swap you mentioned before.
Old 07-13-2010, 09:40 PM   #15
DBLSPRT68
DBLSPRT68's Avatar
Plans are for now to get it to be a reliable family mover/rv hauler. It's got a few things that need attention like the starter acting up and the a/c. Radio dosen't work and door locks are out of wack. I'm probably just going to put my front cap in it in black primer. This front cap is smashed. The running boards are growing on me, they've been on the truck since new. Bottoms of the doors don't even have a rock chip. Truck was bought new in Alabama in Dec. of 88 for $21,000. Not a bad score, since I traded a car trailer for it ; title for title!
Old 07-22-2010, 10:29 AM   #16
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Good looking burban dosent look bad
also thanks for taking the pics of it there arnt many good people left in todays world
Daniel will store the crew cab for me until january so i dont need to get it moved
until january and then its going to Jacksonville, Florida to be shipped out
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 07-22-2010, 09:06 PM   #17
68Timber
I know the pieces fit
68Timber's Avatar
Those hubcaps are the most homely set GM ever made. Putting those wheels and tires on woke the truck up very, very well - Nice score!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-22-2010, 11:10 PM   #18
DBLSPRT68
DBLSPRT68's Avatar
Thanks guys for the good comments. Been working on it, and have fixed a lot of stuff. Will be pulling the RV this weekend for the first time. Starter is replaced and it fixed that issue. JY rear bumper is on. Will be swapping in a JY 89 Sub rad support/grill and left front fender next week. Did a tune up and runs much better I REALLY LIKE THIS MONSTER I'll post some more pics with the swapped front end.
Old 07-22-2010, 11:12 PM   #19
DBLSPRT68
DBLSPRT68's Avatar
Thanks! I LOVE these wheels. They were on my truck before, now I'll have to find another set Bruiser is a Kicka$$ looking Blazer!!!!!! Great job on yours!
Old 07-23-2010, 12:24 AM   #20
68Timber
68Timber's Avatar
Thank you, sir! It's nowhere near as nice as the Sub you just scored, but I have a plan and I'm sticking to it.
The Sub looks great. Even as it is, it'll do what you want all year long.
John
74 Honda Z50 build
Old 08-23-2010, 02:17 AM   #21
DBLSPRT68
DBLSPRT68's Avatar
Update on this rig: I just put over 1260 miles on it last week. The first 500 miles was pulling a 4000 lb car + U-Haul trailer and a Pontiac 400 stuffed in the back!!!!!!!!!!!!!!!!!!!!! I must say, "This thing is AWESOME"!!!!!!!!!!! A few little things here and there, but it is an old truck, but 75 MPH it just glides down the road . If I can find the digi camera, I'll post a pic. Oh, I got 10 MPG on the way back empty My 2005 Honda Pilot only gets 22 hwy and it's a V6. David
