Old 07-09-2010, 10:36 PM   #1
structures
structures's Avatar
LS Engine fuel feed system
I have a 2006 4.8 ls engine and it only has one line at the fuel rails, the feed line. There is no return line nor is there a regulator. See below.
So I understand the factory fuel pump has the regulator, filter and pump all in one unit. Below is an airtex E3609M. Which is like an OEM replacement.
So if the OEM pump has the regulator, filter and pump all together, why are there return lines in the top?
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 07-09-2010, 11:04 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: LS Engine fuel feed system
I'd have to go crawl under a truck to tell you for sure, but I'm pretty sure those extra outlets just connect to the charcoal canister in front of the tank.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-09-2010, 11:19 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
GM swapped from a return type, to a returnless fuel system in '04 I think.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-10-2010, 10:00 AM   #4
Jim_PA
Too much emissions when pumping the fuel up to the hot engine, then back to the tank
And I'm going to run a Corvette style filter/pressure regulator in front of a Walbro 255 inline pump, with an Earls 70micron filter between the pump and the tank. All plumbed with -6AN Aeroquip socketless hose.
And I bought an Earl's -6AN bulkhead fitting to attach to the stock sending unit for a return.
Jim_PA is offline   Reply With Quote
Old 07-10-2010, 10:12 AM   #5
structures
structures's Avatar
Oh yeah I forgot about the EVAP system... My brother in law has an 05 I'll check it out some time.
I want to go with an in tank pump but if I can't figure this out I'll probably also go with the corvette filter/regulator.
Robert
1965 Chevy C10
Last edited by structures; 07-11-2010 at 10:42 AM. Reason: in tank pump not intake...
Old 07-10-2010, 10:32 AM   #6
structures
structures's Avatar
Hey thanks this stuff looks nice. No bulky hose clamps! Sorry never heard of it. I mean I've seen it but I never knew what it was called. Is it easy to install the hose over the barbed fittings? I guess this is how it's done?
Umm I don't think I follow... do you have a picture or link?
Robert
1965 Chevy C10
Old 07-10-2010, 03:36 PM   #7
Jim_PA
Yeah, you just push the fitting onto the hose. It's NOT easy But it isn't coming off either. The stuff is tough as nails, and nice to work with once the hose ends are on. You have to make sure you get the right stuff. Some of it is not as good for heat as others, I'm looking up some info on it now.
My factory tank does not have a return line, so I bought an Earl's bulkhead 90 deg. fitting. I will take out the stock sending unit, and drill a hole through the top, next to the outlet pipe. Then I'll put the bulkhead fitting down in there, and tighten it up with 2 nuts, and attach a piece of hose along-side the factory output line down into the tank. Then I'll have a return line in my factory tank.
Old 07-11-2010, 09:58 PM   #8
Jim_PA
After looking at my 4 yr old aeroquip socketless hose today, I can't recommend it anymore! It's not holding up. I'll be using 3/8 steel with AN adapter fittings.
Old 07-12-2010, 11:06 AM   #9
68GMCCustom
good to know....
Kurt -
Old 07-12-2010, 07:27 PM   #10
structures
structures's Avatar
So what's it doing? Cracking?
Robert
1965 Chevy C10
Old 07-13-2010, 12:42 PM   #11
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
***EDIT - I thought I would put the edit bold so everyone knew I was tarded! It never occurred to me that this was something other than a 73-87! So if anyone saw this before I deleted it, know you know where my brain was!
I'm gonna go look at your build thread, then I'll be back.
*** Edit again - OK, I'm back. What kind of fuel tank will you be using? The original, or something different?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-13-2010, 01:10 PM   #12
Jim_PA
Yep! I guess it works good if you want to replace it every 5 years
Old 07-13-2010, 05:23 PM   #13
structures
structures's Avatar
Well I'm thinking about going with the early classic 23 gallon #911-SFFI. It's so expensive though.
Robert
1965 Chevy C10
Old 07-13-2010, 05:28 PM   #14
cableguy0
I would get in touch with fuelcellguy and have him build you a tank I'm sure he can destroy that price from early classic. heres a link to his website. http://www.aluminumfuelcell.com/index.html
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-13-2010, 05:53 PM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
try david boyd welding, also you dont really HAVE to buy the fuel injected tank, you can just get one to fit your truck for almost half of the FI tank cost. put the pump on the outside along the frame rail.
www.boydwelding.com
Tell him your on the board.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-13-2010, 07:02 PM   #16
structures
structures's Avatar
What pump did you use?
So anybody seen a fuel tank where you don't have to move frame members around, can keep the spare tire location, and have a receiver hitch? Wishful thinking?
Guess I could try to do side saddle tanks.
Robert
1965 Chevy C10
Old 07-13-2010, 07:03 PM   #17
glock35ipsc
I was going to suggest fuelcellguy too.
You could also use a 25 gallon tank from an 87 TBI Suburban, and use an OEM in-tank pump sending unit. That tank and sending unit setup can be found fairly cheap on the board's classified section, or a junkyard.
Even new, those tanks are under $100, a new sending unit is less than $70, pump is about $68, and the filter/regulator is $35. Complete setup for under $300, brand new.
Bob
Old 07-13-2010, 07:21 PM   #18
Jim_PA
Can't speak for him, but I'm using a Walbro 255 inline pump.
Old 07-14-2010, 10:08 AM   #19
Clyde65
Clyde65's Avatar
I used a Pierburg pump form Turnkey engine supply
http://www.turnkeyenginesupply.com/e...at=1&key=parts
Clyde65
Rebuild of Clyde
support our troops!
