07-11-2010, 07:24 PM | #1 |
the pollock
motor pull on a 98
hey gents gotta pull and replace the motor on my 98 blazer.
question of the day is pull motor tranny out as a whole? pull motor seperate from tranny? do i need to pull the radiatior support to get this little bugger out? thanks! any heads up is appreciated. I feel i need the hands of an oriental woman to work on this thing.
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
07-12-2010, 06:22 AM | #2 |
blood type; Retumbo
Re: motor pull on a 98
leave the tranny and rad. support.
this is pretty straight forward aside from the 2 upper bolts on the driver's side of bell housing. I have found it easier to remove the steering intermediate shaft and lift body 2 or 3 inches. another thing that makes it easier is to remove engine wiring harness from under the fuse block and lay it all over the pass. fender. why the motor pull? |
07-12-2010, 04:35 PM | #3 |
the pollock
bad motor no compression.
07-20-2010, 12:48 AM | #4 |
Unfinished Project Club
Check out the build on my 95, Blazer, its not to bad if you lift the body.
Handle every Stressful situation like a dog. If you can't eat it or play with it, Pee on it and walk away. 1996 Dodge Intreped ES Nice car great on gas 1993 Jeep Cherokee. Looking for a swb chevy 73-87 |
07-20-2010, 12:02 PM | #5 |
well if it is anything like the 2.8 i did in our company blazer (1988) i removed the front 6 mounts used the lif tot lift the body and put a 4x4 block under the 2 mounts at the doors. pulled the tranny then the motor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
07-20-2010, 03:55 PM | #6 |
I did the same thing but without removing the tranny
07-21-2010, 06:52 AM | #7 |
well we replaced the tranny and motor
07-25-2010, 04:24 PM | #8 |
I have found it easier to pull the trans with the engine on 2 wheel drive trucks atleast. The body can be left alone
I can still count my vehicles on two... wait three hands. |
