Old 07-12-2001, 06:52 PM   #1
'65 Super Sport 327 700R4
whats that smell?
'65 Super Sport 327 700R4's Avatar
Post '74 GMC Super Custom 15 Hundred, what rearend ratio would it have?
I am picking up a just about perfect '74 GMC Super Custom 15 Hundred in about 2 weeks and I would like to know what ring and pinion set it would have. It has a 12 bolt, but it was ordered with heavy duty springs (atleast 3/4 ton). Would it have 3.07's, 3.42's 3.73's?
Thanks,
Erik
'29 Chrysler model 65 all original, 2nd owner ***FOR SALE***
'63 Impala SS 283, 3-on-the tree, flowmaster 2 1/4" dual exhaust, performer intake, edelbrock 600 carb, chrome 15x8 rally's
'65 Impala SS, built 332, 700R4, 3.73, 2 1/2" mandral bent duals w/H pipe, Flowmaster 40-series deltaflows, MSD Mallory, too many modifications to list
'72 Chevy Suburban 4x4, NP205, TH350, balanced 357 (.040 350), 268 high energy cam, 9.2:1 comp, 1.94/1.50 heads (ENGINE BUILT BY THE GREAT RAYZOR or if you know him RAY, WHO POSTS ON THIS BOARD AND CHEVYTALK), 3/4 ton leaf springs, 4" lift, 35/12.5/16.5 Grabber MT's, Rancho shocks, Rancho dual steering stabalizer, American Eagle 143's 16.5x9.75 6 lug, 4.10's, 12 bolt rear limited slip, Dana 44 front limited slip. Carter 600, performer intake, headers and flowmaster exhaust system very soon.
'95 Impala SS Flowmaster cat-back, K&N, 285/40/17 Firehawks, Dark cherry metallic, 27,000 miles, extreamly fun vehicle
'95 Chevy K2500, ex-cab, long bed, 350, AT, Flowmaster cat-back, 265/75/16 Mud Kings, 16x7.5 Centerline HT cast
wheels, Leer high rise canope, bed liner w/ mat, loaded.**FOR SALE**
***I am looking for a '67-72 pickup, suburban or blazer in the Portland area. Body doesn't really matter but it needs to be in great mechanical condition. $500-$1500 range please. ***
'74 GMC 1500 Super Custom, Factory 3/4 ton springs, built 400sb w/3947040 heads, 475 hp, 750 edelbrock, ceramic headers, TH350, B&M holeshot 2000, 2 1/2" duals w/ H-Pipe, 40-series delta-flow Flowmasters, Gibson tips, Fey Outlaw 8" drop bumper.
'95 Impala SS Flowmaster cat-back, K&N, 255/50/17 G-Force T/A, Dark cherry metallic, 27,000 miles, extreamly fun vehicle
'65 Super Sport 327 700R4 is offline   Reply With Quote
Old 07-13-2001, 06:39 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
Can you get the code for the axel? I would go with either 3.08 or the 3.73. If you can't get the code, raise the entire rearend, put the truck in neutral and turn both wheels at the same time. Count how many times the drive shaft turns in relation to one turn of the wheel. You can get an approximate estimate. Since you just bought the truck, I would change the oil in the rear end. Remove the cover and count the teeth or look for the numbers stamped on the ring. Devide the smaller into the larger number to get your ratio.
I have a 12 bolt that replaced a 10 bolt. It also had heavy duty springs and it's a 3.08.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
