Old 07-18-2010, 06:06 PM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Lift gate supports
Has anyone converted their lift gate to use the gas lift supports? If so where did you get the part and what part number is it. Or what is the compressed and extended lengths I need and what pound supports?
Scott
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 07-18-2010, 10:58 PM   #2
69nova
Re: Lift gate supports
It is a great swap (http://67-72chevytrucks.com/vboard/s...d.php?t=220511) This post covers it well. I recommend a little weaker shock but didn't take the time to find them. Good luck!
69nova is offline   Reply With Quote
Old 07-18-2010, 10:59 PM   #3
Hart_Rod
Hart_Rod's Avatar
Scott
Hart_Rod is offline   Reply With Quote
Old 07-19-2010, 12:22 AM   #4
Scott Johnson
Junior Member
Hey Rob, great post. I did a search at Advance Auto and could find the part # 4220. Was the one you eventually used the 13.5 to 21 inch support that was 76 pounds?
Old 07-19-2010, 09:44 AM   #5
69nova
I did this conversion with my 72 burb and it works great! I asked my 130lb wife to close the hatch for me one day and I turned around to hear her laughing and see her feet are off the ground and she's hanging on the hatch. She did finally get it closed but that is what I meant by a little weaker shock. The ironic part about it is that prior to me doing the conversion she had trouble opening the hatch fully (due to the weight of the hatch)! Great conversion!
Old 07-19-2010, 06:02 PM   #6
Hart_Rod
Hart_Rod's Avatar
You'll have to ask them to look it up and order them.
Old 07-19-2010, 10:49 PM   #7
capev86
the tailgates on our burbs are feather light....try closing the one on a 73-91 burb with the glass that rolls down into it. you have to have strong arms to swing it up.
capev86 is offline   Reply With Quote
Old 07-20-2010, 12:04 AM   #8
Scott Johnson
Junior Member
Went to Advance tonite and the guys there said they didn`t have any specs for the lift supports that they could only look them up by application. I guess I`ll have to order from McMaster Carr. Just to be sure the closed length should be no greater then 13.5 and the extended length should be 21. Not sure of the pound but I found some that were 60lb, will this be enough?
Old 07-20-2010, 08:25 AM   #9
Scott Johnson
Junior Member
Found some at McMaster Carr the extended length is 22.36", compressed length is 12.52". I can order them in whatever poundage I need from 15 to 130 lbs each. What poundage do you guys reccomend I order?
Old 07-20-2010, 11:32 PM   #10
Chevydude56
Chevydude56's Avatar
Don't if this helps, found Strong arm #4220 at
Rock Auto for $10.02 (4 left)
http://www.rockauto.com/catalog/raframecatalog.php
Amizon.com for $23.06
Amazon.com: StrongArm 4220  Volvo 740 Sta. Wagon... Amazon.com: StrongArm 4220 Volvo 740 Sta. Wagon...
Chris
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 07-21-2010, 11:52 AM   #11
Jwill41
Jwill41's Avatar
thanks for the Rock Auto info. Now they only have 2 left.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 07-21-2010, 12:23 PM   #12
Scott Johnson
Junior Member
I ordered some from McMaster Carr along with the rod ends. I will post how they worked out in a week or two when I get them installed
Old 07-21-2010, 07:27 PM   #13
Jwill41
Jwill41's Avatar
I just checked the tracking info and mine are scheduled to be here tomorow. Order one day and receive the next. Now thats cool.
Old 07-25-2010, 11:40 PM   #14
Scott Johnson
Junior Member
Got mine installed today, with the rod ends on mine was too long to use the original mounting holes on the bottom. I had to drill new holes at the bottom and will have to weld me a solid nut in so that the mount will be solid, there is no reinforcement behind the metal in that area. After I get a nut welded in I will be good to go. The 60lb shocks are more that enough to handle the door probably could have used 50lb. Here is a pic of it as it sits now.
Old 07-26-2010, 08:22 AM   #15
Jwill41
Jwill41's Avatar
looking good. From what I have been reading, yours are upside down. The cylinder should be on top so that the rod gets oiled on every stroke. Peobably no big deal but thats what I read somewhere.
I tried installing mine Saturday but broke a couple of the ball studs. I even borrowed a couple from my other trucks and broke them. Those things wont take much tightening. Waiting for new ones in the mail and I will try again.
Old 07-26-2010, 09:00 AM   #16
Scott Johnson
Junior Member
Thanks for the tip, I have to get some shorter ball studs for mine, the cylinders contact the lift gate when it is closed, but should be plenty of room with a little shorter stud. Other than that, I like the conversion.
Old 07-26-2010, 03:11 PM   #17
draggingframe01
Just ordered the last two from Rock Auto. Thanks for the info.
draggingframe01 is offline   Reply With Quote
Old 08-08-2010, 10:15 PM   #18
Jwill41
Jwill41's Avatar
I got the gas struts installed on the lift gate today. They are a little too strong but hopefull they will get easier over time.
Old 08-10-2010, 05:51 PM   #19
72GMC-Burb
72GMC-Burb's Avatar
did the same with struts - love it!
72GMC-Burb is offline   Reply With Quote
Old 08-14-2010, 10:17 AM   #20
Hart_Rod
Hart_Rod's Avatar
Looks good!
Old 04-18-2014, 03:49 PM   #21
chewiebarker
chewiebarker's Avatar
AMS Automotive has a chart of their universal lift supports that allow you to pick length and amount of force you desire. http://www.amsautomotive.com/how-to-...need-see-chart They also have ball studs and other hardware.
AMS Automotive is the brand that Rock Auto carries.
1971 K20 Suburban
2012 LS1500 4WD Suburban
2003 Honda Accord LX V6 (don't tell anyone)
MY 'BUILD' THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=618915
chewiebarker is offline   Reply With Quote
Old 04-18-2014, 04:35 PM   #22
chewiebarker
Actually, I just ordered some Scott Johnson suggested on McMaster Carr. I got the 40lb lift, 20.13 inch extended, versions that include the ball studs for $15.72 each. Can't beat that price! http://www.mcmaster.com/#catalog/120/1222/=rledrz
Part Number 4138T58. Thought about 50lb versions but the 40s should handle it fine. Compressed size is 11.85 inches.
1971 K20 Suburban
Old 04-18-2014, 11:06 PM   #23
72MARIO
72MARIO's Avatar
please let us know how the work out. That's a mod do list before the burb comes out for the summer.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-10-2014, 11:02 AM   #24
BennettGM
BennettGM's Avatar
Hi Chewiebarker - just reading your post on the liftgate shocks - you mentioned you ordered shocks from McMaster Carr and I wondering if you got them installed and did you have any issues with the travel of the shock and the liftgate closing properly?
72 Suburban 3/4 ton 4X4
BennettGM is offline   Reply With Quote
Old 07-25-2016, 08:30 AM   #25
zach_carver
zach_carver's Avatar
How did these end up working? I just ordered them as well and hoping 50lbs are ok. Our suburban needs them bad, the metal current ones are terrible!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
