Old 07-26-2010, 12:18 PM   #1
Juiced06GTO
5.3 into 87 4x4 - what to do with front crossmember?
I was just wondering if anyone has any pictures of what they did with the front crossmember on their 4x4 trucks? I have an idead of what i want to do, I am just not sure if it has already been done before or not. I saw the pictures that Thaelin put up, but his crossmember looks a little different then mine.
Anyone with any exp on the 87 trucks? I will post some pics up this weekend as I will finally be able to get back to working on it!
Juiced06GTO is offline   Reply With Quote
Old 07-28-2010, 02:02 PM   #2
Juiced06GTO
Re: 5.3 into 87 4x4 - what to do with front crossmember?
Anyone have any ideas?
Old 07-28-2010, 02:47 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I would like to see the pics. I don't know what a 4x4 square front crossmember looks like.
What are the specific issues you are having?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-28-2010, 08:54 PM   #4
Juiced06GTO
I will have some pics up this weekend. I've been working pretty long hours and haven't even had time to look at the truck!
Basically when you set the engine down on the motor mounts, the front of the block rests right on top of the front crossmember. There is no room to fit the accessory bracket the holds the ps pump and alt. I still have to extend the motor mount plates back about 1 3/4" and redrill new holes for the motor mounts.
Even with the trans dapt motor mount adapter plates the motor still sits too far forward to meet up with the trans unless i slide everything forward. I'd like to avoid that because that means moving the transfer case, lengthening the rear ds, shortening the front ds, and who knows what else!! I'll have some pics up this weekend to illustrate whats going on with it.
Thanks ahead of time for the help!
Old 07-28-2010, 09:03 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
85burb has a 4x4 suburban and is getting ready to put in a 6.0L...he needs to get in on this one
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-28-2010, 09:27 PM   #6
85burb
85burb's Avatar
I would help you with this but i have no front crossmember...But i will be getting one when i put engine in. This is what i will buy. It may not fit in factory location but it will for sure help. http://www.offroaddesign.com/catalog...rossmember.htm
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 07-29-2010, 08:27 AM   #7
Juiced06GTO
Hmm on my truck there is another crossmember in front of that one, it will be much easier to see in the pictures. I will get them up asap.
85burb, see if they can set the cross member up for an ls engine before you order it!
Old 07-29-2010, 09:39 PM   #8
85burb
85burb's Avatar
It will be a while befor i order it. I am going to put engine in then order one. Still have more parts to order. I will email them tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 08-04-2010, 07:20 PM   #9
Juiced06GTO
Finally some pictures - The rusty spots on the frame are where the motor mounts are, I removed them to weld a plate on them to move the motor back about 1 3/4". The motor hits right about in the middle of that crossmember. My plan is to cut it out, box the ends, and use a piece of 2x4 steel to replace it and move it down a few inches.
Old 08-04-2010, 07:37 PM   #10
Juiced06GTO
Here are some pics of what I started with for those that might not see it in the build section.
Old 08-06-2010, 03:05 PM   #11
Juiced06GTO
The pics give anyone any ideas?
Old 08-06-2010, 04:23 PM   #12
glock35ipsc
Without being able to see it in person, and just thinking out loud here........ Could you brace it real good, then cut the center section out and move it forward, then gusset it enough to retain strength, but provide enough room for the engine to set down in it?
If you have seen how the 2wd guys that "Z" their frame so that it sits lower than a lady bug, that might give you an idea of what I am thinking.
EDIT: Here is a quick crayola cad drawing of what I was thinking. This is looking from the top, and of course the gussets should be all boxed in:
Bob
Old 08-06-2010, 08:41 PM   #13
Ratpowerd67
i have had several 4x4 trucks that didnt even have this xmember on them for some reason, and they are used to suport the frame from twisting without cracking the block. id say ditch the factory one, install the engine, and then fab one up that clears everything. to make it easy,cut the ends off of the old factory xmember, bolt them up to factory location, then fab something up that clears and then weld it up.
Ratpowerd67 is offline   Reply With Quote
Old 08-07-2010, 09:48 AM   #14
Juiced06GTO
Glock, thanks for the input I was hoping you would have some ideas!
Rat, thanks for the info, it is good to know what it was actually used for! Knowing that, I like your idea of just removing it to get the engine in and then fabbing something after the fact. It would be much easier to do it that way and maybe make it out of some tubing with a bracket that would bolt to the frame.
Thanks for the input guys! Hopingto get some more work done on it this week!
Old 08-13-2010, 03:53 PM   #15
SWB4x4
SWB4x4's Avatar
Have you looked into the CPP crossmember? I am curious if anyone here is using one.
J.T.
1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System.
My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140
SWB4x4 is offline   Reply With Quote
Old 08-14-2010, 07:40 PM   #16
Juiced06GTO
I got the motor in to the truck today, had to modify the existing motor mounts and I cut out the extra cross member. I am going to build one after I get everything in, there are two sets of holes on each frame rail/motormount perch that will make a great place to bolt in a removable cross member. I will get pics of what I have done, and then what I will plan to do once I have everything mocked up! It feels good to have finally made some progress!!!
Old 08-20-2010, 06:29 AM   #17
Juiced06GTO
More progress, got the wiring harness modified last night. Things are coming together!!
Old 08-30-2010, 05:21 AM   #18
Juiced06GTO
Some updates -
Old 08-30-2010, 09:51 AM   #19
85burb
85burb's Avatar
Looks good. What is required to make the factory manifolds work?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 08-30-2010, 11:42 AM   #20
Juiced06GTO
All i did was weld up the egr hole on the pass side. I think i got lucky, i did move the motor back about 1 3/4" when i made up the motor mounts which may have helped with some of the clearences.
Old 08-30-2010, 04:38 PM   #21
85burb
85burb's Avatar
Thanks looks great.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
