07-29-2010, 04:39 PM | #1 |
Resident Lurker
Drive Shaft Length (Short tail trans)
I'm in the middle of an engine swap...the new engine is in, it's all the little things that are killing me. Another issue came up last night.
The new engine came with a th350 short tail transmission, so the drive shaft is now about 5 inches short. I stopped by a drive shaft shop on the way home and they said it would be $300 to build a new shaft. Surely there is something out there that will work. Does anyone know which drive shafts will work in our trucks with a short tail th350 trans? I may just head to the junk yard to find one, but where do I measure from to get the correct length? The truck is a swb '72, btw. Thanks.
The Rotten Mule: '72 Chevy Short Step Project- http://67-72chevytrucks.com/vboard/s...d.php?t=417252 "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats."- H.L. Mencken |
07-29-2010, 04:54 PM | #2 |
Re: Drive Shaft Length (Short tail trans)
you measure the space you need to fill then take tapemeasure with you to junkyard and get one that fits
07-29-2010, 06:02 PM | #3 |
its all about the +6 inches
looking at your location... I'm not sure if you have a lot of these trucks in your junk yards or not... not sure if "over yonder" is in the rust belt or not, but these trucks came with short shaft trannys, so it shouldn't be too hard to locate something. A SWB, with a smalll block in the correct location, with a coil rear, would take a one piece shaft 4 ft 10 inches long.
07-29-2010, 06:12 PM | #4 |
Resident Lurker
I'm in Texas.
I didn't realize 67-72s came with short tail automatics. That means I must have placed the engine towers in the wrong frame holes (forward holes) because the drive shaft is not even close to meeting up with the trans. I wouldn't think it would make that big of a difference.
07-29-2010, 08:20 PM | #5 |
Project '67 454
If you don't have many to choose from or can't find the perfect length get one that's too long and have it cut down (much cheaper to have done)
67 C-10 SWB Fleetside 454 (current project) 99 Crewcab SWB Dually 454 75 Datsun 280ZZ430 94 Formula 232LS 454 |
07-29-2010, 09:04 PM | #6 |
Burnouts are therapeutic
what trans was in it before? someone likely did what your doing now in the past. as in they put a long tail shaft trans in and found a diff. driveshaft or shortened the one they had.... jmo
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
07-29-2010, 09:12 PM | #7 |
Resident Lurker
The truck had an inline 6 and a 3spd man on the column, I'm assuming it was original to the truck. Hmmm....
I'll take a few pics and post them up.
07-29-2010, 09:34 PM | #8 |
Resident Lurker
Ok, engine towers are in forward holes. (The only way I could have installed them in the rear holes was if I drilled new holes in the crossmember, but I didn't want to do that.)
Plenty of space between HEI and firewall. Drive shaft installed in rear saddle. But still short by several inches?
07-29-2010, 09:43 PM | #9 |
That HEI shouldn't be that far from the firewall. It should be less than an inch, and a royal b***h to get the cap off, lol.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
07-29-2010, 10:43 PM | #10 |
possibly was the original engine then, the forward 2 holes are for v8 ,it will work in the rear 2 holes but those were originally for 6 cyl .and dist will be tight to firewall . It doesn't look like moving it back will gain you enough for the driveshaft to work anyway . the 6 cyl was positioned in the front holes?
