08-05-2010, 08:28 PM | #1 |
Heat riser tube and manifold cover. Small block.
Very clean set-up. I took the best from 3 sets to put this package together. Thanks to Field & Son for the rear cover, I had been looking for one for quite awhile. Tube was in excellent original condition, steel wooled, primed and painted gloss black. Manifold covers are solid with no rot or bends. Media blasted and sprayed in primer, ready for your choice of high temp. paint.
$95 shipped. Please reply in thread. Thanks, Sharpie |
08-05-2010, 08:43 PM | #2 |
One of the First
Re: Heat riser tube and manifold cover. Small block.
Is it thin anywhere on the manifold sheilds? Are any of the mounting holes (screws) streched out beyond the original diameter? I would like to use original size screws. Intrested. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
08-05-2010, 08:47 PM | #3 |
Hi David, thickness looks good everywhere and screw holes all look to be correct size. 100% satisfaction guarantee, if you don't like it ship it back at my cost!
Thanks, Sharpie |
08-05-2010, 09:09 PM | #4 |
One of the First
Good to know you back your parts. I guess the last question would be: do you think it will fit around a 2 1/2" straight dump GM manifold? It looks like it has a slight bend for a 2WD manifold.
08-05-2010, 09:36 PM | #5 |
Hi David, it fits my 4x4 straight dump manifold fine. Thanks, Sharpie
08-05-2010, 09:51 PM | #6 |
Hi Sharpie, If David Passes I will get in line.
Thanks, Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
08-05-2010, 10:04 PM | #7 |
One of the First
Sounds good, I'll take it. My concern is the bottom fitting around a 2 1/2 " manifold outlet.
PP or MO? Thanks David |
08-05-2010, 10:06 PM | #8 |
Hi David, do you have an O.D. measurement on your manifold? The shield measures 3" without tweaking it. Thanks, Sharpie
08-05-2010, 10:41 PM | #9 |
One of the First
I don't - I'm away from the house until the end of the month.
08-05-2010, 11:05 PM | #10 |
Hi David, I'll leave it up to you. 2 1/2" straight dump might be a strech for a stock turn back cover. Thanks, Sharpie
08-06-2010, 12:14 AM | #11 |
I've got 2 1/2" center dump ramshorn if you need a demension David
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-06-2010, 07:51 AM | #12 |
One of the First
I'll take it. I believe I have a extra outer shield laying around. I could modify if needed. I didn't care to run a AM air breather on this truck.
PP or MO? Thanks Jaros for the offer. |
08-06-2010, 08:15 AM | #13 |
Hi David, Paypal is fine. denscustom1@hotmail.com
Thanks, Sharpie |
