08-13-2010, 06:33 PM | #1 |
axle options
I am heading to the the pick and pull tomarrow morning searching for a diffrent rear end for my 77 c10 longbed. Does anyone know what i need to be looking for and in what veichles? Im after a 12bolt with posi and the highest gear ratio i can get 342, 373, 410. Any help is always greatly apreciated.
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
08-13-2010, 11:44 PM | #2 |
Re: axle options
I'm not sure what range of years have interchangeable axles, but the only way I know to check gear ratio is to turn the rear wheels and count the revolutions of the drive shaft - might be hard to do with truck in a junkyard.
I have a 4:10 C20 with a 454 and it sucks money out of my wallet. I assume that you are aware of the lack of fuel economy, and lower top end mph when on the highway. When I was growing up, we called 4:10 and 4:56 low gears - guys put them in their 1/4 mile cars. Some call them high gears because of the high numbers. |
08-14-2010, 09:22 AM | #3 |
Re: axle options
haha yea i am fully aware of the gas mileage its is not my daily driver by any means just my toy. Found out I have a 2:08 ratio wich is really making my 357 small block and big cam cranky. thank you for the help bud.
08-16-2010, 06:55 PM | #4 |
Re: axle options
Unless your towing, the 3.42 is plenty of gear. Ive got a mild 350 and i can get a second gear scratch with 3.07s. Thats with 295/50/15 on back.
08-16-2010, 07:26 PM | #5 | ||
Re: axle options
The highest I have ever seen is 2.56
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
08-16-2010, 08:43 PM | #6 |
Re: axle options
i did the tire rotation trick and one rotation of the tire gets me just shy of 2 turns. If I am mistaken please set me straight. Although I have to say I did that on several rear ends at the pick and pull and seem slike out of 10 truck they all turned the same amount im lil cofused if I am doing it right or not.
08-16-2010, 09:46 PM | #7 |
Re: axle options
you need to mark where your driveshaft and wheel are to begin and count how many times each make a full revolution until they return to the original position, that should get you real close. Math differs if it's a posi or open rear
08-17-2010, 03:27 AM | #8 |
Re: axle options
Now if your going to be running tall tires or 4x4 setup the 3.73-4.11 may be the ticket. You really need to consider the tallness of the tire. For street with a normal or low profile tire 3.42 if more than enough. 3.07 is great all around highway and town gear for normal size tire.
08-17-2010, 05:24 AM | #9 |
Re: axle options
i run 255/60/15's out back but am going taller here soon with a 275/70/15 i think. its not my daily jus a toy that i enjoy from time to time so 3.73 or close to em will be alot of fun to play with. thanks for all the help everyone
