08-14-2010, 11:52 AM | #1 |
Which bag brackets?
I need help choosing which bag brackets to buy and how to install to give access to bolts and ports.
I have a 67 C-10, stock crossmember, control arms, and trailing arms. I think I understand the front setup: Upper plates which bolt in, lower cups which weld in? Then I need to drill holes to run the air lines out the top somewhere? Is that upper fitting a straight or a 90? The more confusing part is the rear. I guess I am going to place the bags where the old coil went, on top of the trailing arm. For the bottom mounts, do I weld a cup onto the top of the arm with the cup facing down, and feed the bag bolts and air line in the small space between the cup and the arm? Or maybe drill the side of the cup for the airline? Do I notch the top of the arm for more space? Anybody got photos of these details? Suicide said I could weld studs to the bottom of the cups and run a bolt down through the arms, but I didn't understand, because there is no bottom on the cup. Am I not getting this? And on the top of the rear bags, my frame has a flat plate for the old spring seat, and a hole where the old spring retainer was. Can I just drill 2 holes for the bag bolts through the frame, then run the air line up through the old center hole? Guess I just need to see some photos. Not a lot of this to look at in my town. |
08-14-2010, 03:12 PM | #2 |
Re: Which bag brackets?
bolt in the top plates and then bolt the bags to it ... bolt the lower cup to the bottom of the bag and just sit in the pocket in the lower a-arm ... you're good to go.
no need to weld or bolt the cup to the lower arm ... it's being held in place with the bolt in the top. |
08-14-2010, 05:32 PM | #3 | |
For the rear you can bolt the bags in place of the coils (if you drill the requisite holes in the frame for mounting & the air fitting) or you can make a 'hat' that allows bolting the bag in using the stock coil mounting holes. The 'hat' method will limit drop vs. the drilling & direct install. Don'f forget the need for an adjustable Panhard bar (the longer the better) & some shock relocators.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-14-2010 at 05:35 PM. |
08-14-2010, 05:38 PM | #4 |
you might also want to consider a C notch for the rear ...
08-14-2010, 07:59 PM | #5 |
Redefining LowBudget
you might want to cut 1" off the lower front cups to for a better stance..this allows the bag to ride in the middle
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
08-14-2010, 10:17 PM | #6 | |
08-15-2010, 01:16 AM | #7 | |
Okay, I think I got most of it. Thanks.
More questions: For the front air lines, it looks like I can drill a hole in the rear of the upper spring cups to run the air line out and up into the frame. I don't get this part for the top of the rear bags: Quote:
As for the shock relocators, is that on the rear? And is that both top and bottom? Does the front also need relocators? And when you say "cut 1" off the lower front cups for a better stance", do you mean make the cups drop down into the LCA a bit more? What would be a good final height for the cup in order to fit in there the best? Finally, the panhard bar. Can I keep the stock stud on the differential, and stock bracket on the frame? I read here that the bar rubs some C-notches. I was going to use a CPP or Suicide notch. Last edited by jnocero; 08-15-2010 at 01:25 AM. Reason: Not cle |
08-15-2010, 02:06 AM | #8 | |||
Yes. Possibly.... Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-15-2010 at 02:13 AM. |
08-15-2010, 02:41 AM | #9 |
for the front, i built upper plates and also cut a hole to make it simpler to keep an eye on the fitting and bag bolts
08-15-2010, 03:56 AM | #10 | |
Reason for asking i am in the UK and shipping for this item is over £100 quid and i am not willing to pay that when i can make one myself. |
08-15-2010, 08:26 AM | #11 |
If your truck is apart you can trace the upper mount and cut out the LCA check my build
02-06-2011, 02:56 AM | #12 | |
02-06-2011, 09:51 AM | #13 |
Step bit would be my choice.
05-24-2011, 10:11 PM | #14 |
bump for a helpful thread
Posted via Mobile Device |
11-12-2016, 04:30 AM | #15 |
Awake old thread!
Can anyone make a stencil of the upper plate? Rather make one and can't have truck down for more than a day |
11-12-2016, 05:23 AM | #16 |
Diggin The SquareLife
why not buy some an wait till u get them an put them on
11-12-2016, 05:30 AM | #17 |
Because I can make some and not taking front end apart till I get all the parts together..
I can make some bolt in front and back but just need templates |
