![]() Join Date: Dec 2008
What is the best way to test the HEI Distributor to make sure everything is working properly? Reason I ask this, during all of the robbing of parts my nephew did, I think he swapped distributors on me. Is it possibly the gears are worn out? It's just not acting right. Doesn't seem to be getting the right amount of fire to the plugs, has a new rotary cap, and button, coil. well all new inside Just can't get it to time right. You can set it, and next time you start it it's off again. That's why I'm thinking maybe the gears are worn out. O it has a new timing chain and cam. Well, not new, but a couple of years old. Everything was working fine, before parts were stripped What would be a good cheap replacement for a 81 GMC Sierra Grande 305 SBC
Last edited by nbpro; 08-15-2010 at 11:46 PM. Reason: O it has a new timing chain and cam. Well, not new, but a couple of years old |
Re: HEI Distributor
Skip White looks like my best buy
Re: HEI Distributor
Does your distributor have 4 wires coming out of the back going to a plug in the engine compartment? The wires should be going into the firewall on the passenger side.
Re: HEI Distributor
my brother just told me he's pretty sure it was swapped and the distributor is pretty worn out. he remembers that my nephew telling him he needed a new one for his. so that's gonna be my problem. if you wanna delete this, that's fine. thanks for the help.irishman999
Re: HEI Distributor
Thanks to this site i learned there was a spark control module on my truck, it seemed to be causing me timing problems. I was just wondering if your truck possibly had one.
Re: HEI Distributor
spark control module is new
Re: HEI Distributor
Its still most likely your problem. It can change the timing. Your best bet is to just bypass it. They didnt work right when they were new. The aftermarket ones never work right. Just unplug it from the distributor and splice the green and black wires. Your esc distributor will now function like a normal hei.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Re: HEI Distributor
No body mentions to leave it unplugged after you splice it haha. I plugged mine back in and drove it a while, now im having some similar problems with my distributor.
Re: HEI Distributor
splice the green and black wires to each other ?
Re: HEI Distributor
Yup and then just leave it unplugged. After you do that you will be able to set your timing and it wont move.
Re: HEI Distributor
nice litte right up Changing To A Non-ESC Distributor
http://www.73-87.com/7387garage/drivetrain/escrepl.htm |
