Old 08-16-2010, 10:06 AM   #1
mcrich01
Steering colum on a 89 Burban
Here is my question I have a 89 bur that i had to stop driving because of the steering it is very loose and sways all over the road. What is the problem? Because I would love to put it back on the road.
Rakkasan 4 life
mcrich01 is offline   Reply With Quote
Old 08-17-2010, 12:34 PM   #2
tobiahr
tobiahr's Avatar
Re: Steering colum on a 89 Burban
multiple possibilities. worn pitman arm, worm tie rod ends, worn or loose rag joint, bad steering gear (rare), cracked frame near steering gear. the best way to check for any of these is with the engine off have someone rock the steering wheel back and forth. look for the component that moves more than its counterpart, i.e. the rag joint will let the top half of the steering shaft move while the lower part does not.
tobiahr is offline   Reply With Quote
Old 08-17-2010, 12:51 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Or do you mean the actual steering column itself has a lot of movement in it? These columns have a set of bolts that get loose down inside, very common problem. Not a big deal to fix, just a lot of patience and a few special tools.
This was a good link I found a while back, very helpful in the repair of the issue.
http://www.buickperformance.com/tilt...lumnwobble.htm
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-17-2010, 04:03 PM   #4
trenchwarfare
I'd also check all the gear box bolts. It may have been knocked around enough like mine was.
____________________________________
trenchwarfare is offline   Reply With Quote
Old 08-17-2010, 06:59 PM   #5
mcrich01
Thanks for the information but I thinks it's both in the colum at the point and in the Tilt pivoit and under the hood near the gear box. I was thinking that it might be smarter to replace the complete colum and gearbox.
Rakkasan 4 life
Old 08-18-2010, 01:49 PM   #6
tobiahr
tobiahr's Avatar
i think rebuilding it would be pretty easy and a lot cheaper see http://en.allexperts.com/q/Steering-...uck-w-tilt.htm
Old 08-18-2010, 02:12 PM   #7
mcrich01
thanks for the link I might give it a shot
Rakkasan 4 life
