08-19-2010, 11:19 PM | #1 |
GM ONLY BABY!!!
What to use for lower radiator hose?
I've installed my 6.0 for the last time finally. I have the 99 upper radiator hose, but what are you guys using for the lower?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
08-20-2010, 09:49 AM | #2 |
Next project: 1970 K10
Re: What to use for lower radiator hose?
I used both the upper and lower hoses that came on the 5.3l. Both fit like a glove, and the lower was practically the same shape as the truck's original hose.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-20-2010, 10:29 AM | #3 |
GM ONLY BABY!!!
What year 5.3? Should I get a 99 just like the upper?
08-20-2010, 10:45 AM | #4 |
I used the stock 350 hose that was originally in the truck. I had to trim it down a little, but it also fit very well
08-20-2010, 10:50 AM | #5 |
GM ONLY BABY!!!
Ya, I mocked it up, and considered cutting off some on the water pump side.
08-20-2010, 11:10 AM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
could I see some pictures please? the angle of the waterpump and radiator is extreme imo and my stock lower hose kinked pretty bad so I used a flex hose which I dont like, please show me what you did
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-20-2010, 11:26 AM | #7 |
This is the hose off of the 2006 engine. I imagine they would be the same from 99-07 at least. I also trimmed a little off the water pump end. I could have used either this hose or the one off of the small block, but this one was in much better shape, so I used it. Fits perfect with no kinks.
08-20-2010, 11:32 AM | #8 |
GM ONLY BABY!!!
Kewl, thanks again Glock.
08-20-2010, 07:44 PM | #9 |
GM ONLY BABY!!!
I bought 1 for a 02 and since I have a/c already in my truck the inlet and outlet of the radiator is bigger, therefore I really had to stretch the hoses to get them on. what a pita.
08-21-2010, 01:32 PM | #10 |
glock, how wide is ur radiator, I have the stock 65 and it is only like 25" wide so the lower hose is really contorted.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 08-21-2010 at 01:33 PM. |
08-21-2010, 07:06 PM | #11 |
Ya, how wide is the radiator? I found the perfect one for my 56 but it's a narrow radiator. 21710 Gates, but the 90 degree turn on the end has to be cut off.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
08-22-2010, 11:45 PM | #12 |
It's about 28.5" inside the tanks. It's the truck's original radiator.
