08-25-2010, 09:50 PM | #1 |
I dont drive fast,, I fly low!
lowering questions????
im wantingto lower my 67 gmc. it has leafs in the back, andi was wondering how would i g about notching it and bagging it with leafs? And any websites that will have te best prices on notches
____________ /_______\ (OO==||==OO) 67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima |
08-25-2010, 09:53 PM | #2 |
im wanting to lower my 67 gmc, but it has leafs int he back, wat are some ways that i can go about notching and bagging with leafs? and if you have any website with good prices on notches ... let me know
08-25-2010, 09:53 PM | #3 |
Old Skool Club
Re: lowering questions????
I like Early Classic Enterprises. I have their 2.5/4.0 drop on my '69 SWB Chevy. Of course, there are other vendors including some on here.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-25-2010, 09:59 PM | #4 |
Grandpa in the rustmobile...
ECE is nice for suspension, whats your budget first and how low ya wanna go?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-26-2010, 03:00 PM | #5 |
ummm im not really sure on the budget, i dont know the price ranges of them? and as far as how far i wanna lower it.... all the way.
08-26-2010, 04:18 PM | #6 |
CPP has a standard & HD bolt-in c-notch.
Porterbuilt has a bolt-in step notches @ differing heights depending on your needs. SuicideDoors has step notches. KP Components has step notches. On your leaf equipped truck, a flip kit gets you around 5-6" of drop. To match that, you'll want spindles, dropped springs, & optimized shocks (different shocks or brackets).... or an aftermarket xmember. If you want bags out back, your options are parallel 4-bar, converging 4-bar, 3-link, KP Components 6-link, Extensive metalworks 2-link (not to be confused w/a factory 6x-72 GM truck truck arm set-up), & aftermarket truck arm set-ups (Porterbuilt has one that allowns the rails to lay). To compliment these, you'll change out the front coils for bags. That should be enough homework for now.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-26-2010 at 04:21 PM. |
07-21-2011, 12:18 PM | #7 |
ok need a little help ..... I want to lower the rear of my truck it has leaf springs and i see that you can purchase a flip kit .... well i am too cheap to do that .... and i really don't want to hack the frame up... can i just take the spring apart and use like one or two of them to get my ride a little lower i mean i really don't want to be on the ground .... just a little lower like 1 or 2 inches would be great .... Thanks
07-21-2011, 12:39 PM | #8 | |
08-02-2011, 11:19 AM | #9 |
I pulled the overload and the next spring. I also used a 1" drop shackle. Lowered the rear 3.5". No wheel hop, and still able to load it up if I need to.
08-02-2011, 02:19 PM | #10 |
nice ............ Thanks for your help .......
08-02-2011, 06:16 PM | #11 |
What does the drivetrain consist of?
08-03-2011, 09:17 AM | #12 |
08-03-2011, 09:21 AM | #13 |
Nothing right now. I have a 427 big block and a 350 turbo trans. I plan to use. The truck was a 305 with a 3 speed manual trans. Later on I'll probably swap out the trans for a 5 speed manual I just like shifting those gears ..... I put a link of a video i shot after getting it home.
08-03-2011, 09:22 AM | #14 |
08-03-2011, 08:16 PM | #15 |
I have a 350. Originally it had a th350, now it has a 700r4. I should add that it still has 3 springs in it.
08-06-2011, 09:51 PM | #16 |
Cool can you post some pictures for me ????
It's been a long time coming... It's time to get it done.. |
08-11-2011, 10:21 PM | #17 |
Sorry it has been awhile. What pics would you like?
08-12-2011, 08:51 AM | #18 |
some of the rear axel setup you have ...
08-13-2011, 06:41 PM | #19 |
Not sure if these will help much. I have a pic of the drop shackle. It is from ECE and is a 1" drop. I included a pic of the 3 springs in the truck. I also included a pic of the 2 I took out. If you would like more let me know. I can pull a wheel off later this week if you would like that pic. With those 2 springs taken out, and the drop shackle, it lowered my truck about 3.5"
08-13-2011, 10:24 PM | #20 |
Thanks so much that is very helpful just what i was looking for .....
08-13-2011, 10:27 PM | #21 |
just one more favor can you take a picture of your truck.... just so i get an idea of how low it is...... thanks
08-21-2011, 12:22 PM | #22 |
Will do. Will try today or tomorrow.
08-22-2011, 05:01 PM | #23 |
Here is a side pic of my truck. Not the best but my street isn't very level. It gives an idea though. This is my truck lowered 3.5" all the way around. I am thinking of dropping the rear 1-2" more. I don't mind the rake, just want a little less. Sorry it's dirty, we had a dust storm the other night and I haven't had time to clean it yet. Hope that helps you.
08-22-2011, 05:12 PM | #24 |
Thanks so much ..... You have been alot of help .... I think I am gonna do the same thing to mine.... I'm gonna wait to lower the front till i get the engine together and in because I just don't know how low it will make it with me changing from a small block engine to a big block ..... Thanks again.....
08-26-2011, 03:01 PM | #25 |
Any time. I had a hard time finding info when I lowered mine. Just decided to do it. Makes it easier when someone can help out.
