Old 08-26-2010, 03:01 PM   #1
mcrich01
Talking Front Dash for a 89 Suburban
Hello to all fellow Burban drivers. I am thinking of doing some major swaps in my bur. And I want to pull the dash out anyone have some simple step by steps or Tips to keep me from hurting myself??????/
Rakkasan 4 life
mcrich01 is offline   Reply With Quote
Old 08-27-2010, 10:01 AM   #2
justpball
justpball's Avatar
Re: Front Dash for a 89 Suburban
it is very easy, there are about 4 screws under the front edge, a couple on the sides and then it slides back toward you, go slow there is duct work on the passenger side you will have to undo, if you pull your glove box down you can reach in there and take it loose before you pull the dash, and this is of coarse after you pull the plastic piece from the front of your gauges, which is just a few screws...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 08-27-2010, 12:38 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Yup, 8 screws on the instrument cluster bezel and radio knobs, 4 screws on the bottom edge of the pad, one screw inside the passenger jamb area and off the crash pad comes.
If you're just talking about the instrument cluster/gauges, just about as simple. Get the bezel off and you'll see all the screws holding the gauges themselves in place, or if you're after taking the cluster out as a unit, you'll see the screws holding it all in place. You'll have to reach in behind the speedometer and unhook the cable, otherwise there is just one electrical plug on the backside of the cluster assembly.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
