08-29-2010, 10:06 PM | #1 |
94 LT1 swap into a 71 c10
I am looking at buying a complete 94 z28 with an LT1 motor for $600. He was originally selling just the motor and then called me back and asked me if I would be interested in the whole car. We went back and forth on the price a little bit and Im going to call him back tomorrow. Is this a fairly reasonable swap to do? Are there a lot of extra expenses after buying the donor car?
I keep goibng back and forth from just dropping a carbed 350 automatic and doing some thing a little more interesting. Anybody done this swap and have advice for me?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
08-29-2010, 10:30 PM | #2 |
Re: 94 LT1 swap into a 71 c10
Haven't done it myself but several have there should be several threads on the swap. I think the biggest headache is getting everything you need from the donor which sounds like you would get. And the biggest expense is having the puter reflashed to custom for your application. But that being said. If you have heard this thing run. And your not in a hurry with it for transportation purposes I'd say yes. I've heard having the puter flashed is around $300 or so and takes a few weeks to have done. Someone that has done this swap should be able to guide you to a more reasonable person for the task. That sounds very reasonable of a price, I would go that route.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
08-30-2010, 02:29 PM | #3 |
The only thing that you have to do for the PCM is to remove the VATS if the motor is stock, I can do that for $125 shipped. Just send me the PCM and a MO for $125 and I will send it back to you via USPS the next day.
The only other thing you will need is to take the stock harness and make it work with your truck, pretty "simple". I would have opted for a 5.3/6.0 LSx based engine instead just to get away from the Opti but that is just me (coming from a LONG line of LT1 cars),
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
08-30-2010, 03:31 PM | #4 |
Thanks, Shon! Is a 4.8 motor just a smaller verion of the 5.3? I have found a few ls motors for sale with engine and trans and supposedly all of the computer equipment and harnesses, but it was my undertanding that I should get the whole car to make sure I get the right parts. I found this ad on craigslist for a 1999 truck motor and I can hear it run. What else do I need out of the donor truck to make my swap work?
Thanks! http://jacksonville.craigslist.org/pts/1923154382.html
08-30-2010, 03:36 PM | #5 |
The only thing we use from the donor trucks are the wiring harness and fuse block under the hood, other than the motor/trans.
If you get the under hood fuse block its about 5 wires to hook up, other wise you can make your own fuse block or buy them the set up from Current Performance (out of FL; its what I used on mine). 4.8 is a smaller version of the 5.3, 4.8 is a good start, but i would get at least a 5.3. We pay about $700ish here for a running 5.3 will all PCM/harness/acessories. IF the truck is drive by wire, ie the TB is not cable driven, you will want the TAC module, and this is the gas pedal assembly with associated wiring and 'box'.
08-30-2010, 03:55 PM | #6 |
Is that $700 for engine and transmission, or just the engine?
08-30-2010, 03:58 PM | #7 | |
08-30-2010, 03:59 PM | #8 |
engine and harness/PCM, trans are normally $400 I think....we have not bought a full combo (motor/trans) in a long time, been running TH350/400s behind the other ones we picked up lately....
08-30-2010, 04:18 PM | #9 |
I didn't think you could run an older transmission behind the newer motor. I guess you can program the pcm to do whatever you want?
08-30-2010, 04:27 PM | #10 | |
Varies by year, some 03s have it, just have to see the motor/TB to know.
Most 4.8/5.3s need the spacer, some 6.0s do not. here is the spacer I am referring to; I have these machined locally: https://securehost98.hrwebservices.n...&productId=239
08-30-2010, 04:36 PM | #11 |
Does that make the swap simpler or am i better of getting the transmission with the motor?
08-30-2010, 06:16 PM | #12 |
A 5.3 is a 4.8 with a longer stroke.
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
08-30-2010, 08:01 PM | #13 | |
I was going to tow with mine so I wanted the 6.0/4l80e combo, now that I probably will not tow I have thought about going to a TH350 set up. if i was going to cruise the truck then I would get a 4spd auto, race the truck stick to the 3spd autos.
08-30-2010, 08:26 PM | #14 |
Dang Shon, That '71 of yours is SWEET. Looks like a killer drive train. Be sure to let us know how the mileage/driveability turns out. With the bags out back, it should ride pretty nice...
08-30-2010, 08:34 PM | #15 | |
I love the truck!!! 114k original miles!! when cooler air is here I drive it every day to work and where ever else I go. see truck in action: got plans for it!!! mods are my Speed Density tune, DT headers, full exhaust with 22" Magnaflows....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 08-30-2010 at 08:36 PM. |
