Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 08-30-2010, 08:02 PM   #1
chevydragking
1996 s10 headers
would shorty headers for a g body work with a v8 swap
chevydragking is offline   Reply With Quote
Old 09-05-2010, 03:13 PM   #2
chevydragking
Re: 1996 s10 headers
or would first gen s10 headers fit it
Old 09-05-2010, 08:00 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can find swap parts and details here: http://www.s10forum.com/forum/f10/sw...estions-23481/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-15-2010, 08:56 PM   #4
v8blaze
the v8 conversion headers will fit both body styles. But for headers you will need to stick with ones made specifically for a V8 swap. Hedman, sanderson, and patriot make a set that are pretty much the same design and work great. Hedman also makes 2 long tube types for a gen 1 style small block. One set stays inside the frame, and requires the use of a certain type of motor mount (its a plate that uses a stock v8 clamshell) and then a type that wraps two tubes around the frame and i believe (not 100% positive but the manufactuer will be able to tell you what mounts work)will work with both types of conversion motor mounts. All the shorty headers work great with the 2.8 style frame mounts like the ones JTR sells. LEt me know if you need any other info
v8blaze is offline   Reply With Quote
