Old 08-31-2010, 05:27 PM   #1
jjmorrse
anyone tow with suburban
I have a 1991 350 auto suburban 1500 that I use to tow my wife's 2 horse trailer. Anyone else on this forum tow? if so, any common problems that occur, or are there proven upgrades that help durability, etc.
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
Old 08-31-2010, 07:15 PM   #2
blakeduren
Re: anyone tow with suburban
Rear Air bags?
Rear sway bar?
What type of brake controller do you have?
What is the total weight of the loaded trailer?
Total tongue weight?
Do you use a W/D set up?
Suburbans in general are a pretty good towing set up.
Blake
blakeduren is offline   Reply With Quote
Old 08-31-2010, 10:38 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me I would invest in a rear air bag system. The small helper bags with a schrader fill valve is good. Adding a compressor with air gauge and controller is better. It's really nice to be able to level your ride based on the load you have.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-01-2010, 12:25 AM   #4
jjmorrse
The truck is stock. Receiver hitch. The trailer is a basic 2 horse, no tack room, about 3000 lbs. Each horse is about 1200 lbs.
jjmorrse
Old 09-01-2010, 12:38 PM   #5
justpball
justpball's Avatar
i agree with the rest, get you some helper bags...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 09-01-2010, 01:17 PM   #6
jjmorrse
thanks
jjmorrse
Old 09-01-2010, 01:33 PM   #7
83burban
Add an external transmission cooler, and if its a 700r4 then don't tow in D - only 3,2,1.
Best buy would be rear helper bags - helps in braking, cornering, stability.
Next I would get a trailer brake controller if the trailer is so equipped.
83burban is offline   Reply With Quote
