Old 09-02-2010, 03:11 PM   #1
longbedted12
Engine making clicking noise. What could it be?
Hello, my name is christian and i am a new member to 67-72 website. i just recently purchased a 1970 c-10 lwb and i have had alot of problems with it to say the least. I havent started any body work or anything because i was hoping to get the truck in good running order before i go further.
Just recently my engine has been making this really annoying clicking noise. It does it whenever the engine is on and speeds up whenever i accelerate. I have been wondering if it is the fan belt but im not sure. i have the original 307 engine in the truck so i assume it could be a number of things.
Any info would help!
Thanks, Christian
longbedted12 is offline   Reply With Quote
Old 09-02-2010, 03:19 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Engine making clicking noise. What could it be?
Tick/click, Clack, Knock?
Tick/click = exhaust leak or lifter starved for oil
Clack = loose rocker arm.
Knock = nothing good...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-02-2010, 03:28 PM   #3
longbedted12
If i would have to guess it would be a ticking noise. So would a simple addition of some oil fix the noise or is there something else?
My pan does leak about a two to three drops of oil a night so i might be low.
Old 09-02-2010, 03:38 PM   #4
BlackTopMotors
I agree if it's more of a ticking sound especially if it's an old motor, try fresh oil...higher viscosity may help as well and or oil additive. That would be a good start and fresh oil...aint a bad thing... Hope that's about it...check to make sure you don't have any exhaust leaks...might as well eliminate simple possibilities. Hope you get it resolved soon.
BlackTopMotors is offline   Reply With Quote
Old 09-02-2010, 04:10 PM   #5
raycow
While you are in there, it couldn't hurt if you take off the belt for a test - just in case.
Ray
raycow is offline   Reply With Quote
Old 09-02-2010, 04:16 PM   #6
cdowns
cdowns's Avatar
i'd check the torque converter dust shield to see if the flexplate teeth are hitting it// also the fan shroud gets hit by the fan with sagging engine mounts or poorly iattached shroud
Old 09-02-2010, 06:06 PM   #7
Psycho71
Psycho71's Avatar
If it's got headers on it I'd be looking real good at the gaskets at the heads, and second (least likely for what you're describing) the collectors. A leaking header gasket at the head can easily sound like a lifter ticking. And an oil change could never hurt anything either.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-11-2011, 02:41 AM   #8
CEE1NG_RED
I have the same issue...seems like it's coming from the driverside. More towards the bottom, where the engine and tranny are located. I'm a novice at this, but the sound is near where the flywheel is at (the rotating mechanism that's under the truck where the engine and tranny meet).????
CEE1NG_RED is offline   Reply With Quote
Old 01-11-2011, 06:55 AM   #9
cdowns
cdowns's Avatar
plastic dust shield getting hit by teeth of flywheel
Old 01-14-2011, 01:12 AM   #10
mudmizer
mudmizer's Avatar
If the truck is an automatic, somtimes a crack in the flexplate, near the crank shaft bolts will make a clicking noise. Not very likley your problem but it does happen once in a great while.
68 4x4, 454, 4 speed, disk brakes both ends,
Sold my 69 SS396 Elcamino when young & stupid
mudmizer is offline   Reply With Quote
Old 01-14-2011, 01:32 AM   #11
60ratrod
yes, i do
60ratrod's Avatar
when the flexplate on my 72 went it made a completely distinctive noise sounded more like a rod/main was going out. but if its coming from the trans area i would look to see if it has headers and look to see if the collector gaskets aren't shot. this is what my flexplate looked like when the trans shop pulled it off. had them replace it when the trans went. and this is pretty close to what mudmizer was describing. and i still got the flexplate since when it went it looked like mickey mouse
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 01-17-2011, 03:46 AM   #12
CEE1NG_RED
What was the cost to change this??
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
Old 01-17-2011, 03:52 AM   #13
60ratrod
yes, i do
60ratrod's Avatar
Well the whole job cost me $1276. That included the tow, carrier bearing, tranny overhaul. I had a new flex plate in the cab so they just used that one
1970 lwb, 307, clicking noise, engine
