09-05-2010, 01:30 PM | #1 |
unigue to 67'
was looking for info on parts and pieces that would be specific to 67's
such as,no side marker lights,kick panel vent pulls,wing vents etc... my 67'project has only one visor and no holes where the passenger one would have been,.... also on the use of a 327 engine,history and usage,what was the last year they were used in these trucks thanks, |
09-05-2010, 05:58 PM | #2 |
Re: unigue to 67'
If you have only one sun visor, this means the truck did not have the custom comfort option, which mainly consisted of extra insulation, dual visors, and full foam seat. The custom comfort option was available even on base model trucks. The 327 was introduced in Medium Duty trucks in 1962, became a standard option in mid '65 on 3/4 tons. Became a standard option in the whole light duty line in '66. Reworked in '68 with larger bearings. 1969 was replaced by the 350 in the pickup line.There are cases where the 327 was special ordered thru COPO on early models.
09-05-2010, 06:27 PM | #3 |
Re: unigue to 67'
283's were standard V8 with 327 Special Ordered in 67. 307's replaced the 283 in 68 as the standard V8. I thought. Some 67's passenger door arm rest wasn't installed in addition to no visor. (That's really cutting back on comfort.) The ignition bezel is a different size than the other models. What about bullseye clear back up light lens and the chrome around the fleet tail lights are slightly different than the rest of the years?? I think the west coast mirrors were only available in 67 and 68. Tripods 69 and later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
09-05-2010, 07:22 PM | #4 |
People know me
Re: unigue to 67'
Mine has a differnt rearview mirror bracket, I had no armrests on either side, and no passenger visor. I believe the auto columns had a metal shifter indicator and a shorter pointer as well.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
09-05-2010, 08:13 PM | #5 |
Sisyphus was my mentor!
Re: unigue to 67'
Non-recessed ignition switch, the clips that hold the sunvisor up are different - (they have a larger hole than later years) & knurled interior switches. Also, 67's have the cool factor that the later years didnt have either...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 09-05-2010 at 08:14 PM. |
09-05-2010, 08:21 PM | #6 |
Re: unigue to 67'
When you make a list it gets longer than you realise. I looked in my stash found my 67 Tail B/U Lens the top one is later years and repo's are similar. The rare CST Chrome 67 only Mirror, most were black.
09-06-2010, 03:24 AM | #7 |
Re: unigue to 67'
I pulled a chrome rearview mirror bracket like that off my Dad's '64 Olds station wagon when we junked it (with a blown out 455). That was in the early '70s. When I bought a '67 K/10 Suburban in '93, the P.O. had a cheap repop '72-style glued-on-the -windshield mirror. It shook so bad you couldn't see out of it. I rememberd my souvenier of the old station wagon and dug it out. It mounted on the '67 like it was made for it. Still there. Although the Sub is lying fallow "until my ship comes in."
09-06-2010, 04:15 AM | #8 |
Re: unigue to 67'
cigarette lighter is not bezeled or rescessed last year for buddy buckets being factory on all csts
09-05-2010, 08:29 PM | #9 |
Re: unigue to 67'
Fuse box is mounted sideways. Last year for the small window cab. No Aux battery boxes. Paint on dash face & glove box is wrinkled. Door exterior handles are different internally. No ACC. position on ignition switch, only off/on/start. Also last year for the SM420 4 speed.
09-05-2010, 08:29 PM | #10 |
Re: unigue to 67'
Ashtray is also one year only. CPNE schooled me on the fact that the outside door handles are 67 only. Seatbelts are 67 specific. Inside door handles, wing window latches. This is going to be a fun thread! Keep them coming! Sharpie
09-05-2010, 09:57 PM | #11 | |
Re: unigue to 67'
Posted via Mobile Device |
09-05-2010, 09:30 PM | #12 |
Grandpa in the rustmobile...
Re: unigue to 67'
I pulled a mirror from 67 gmc and it looks nothing like the one posted above.....
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-05-2010, 10:11 PM | #13 |
Re: unigue to 67'
Exterior door handles have a different angle to the mounting bolts (doors have a reinforcement plate inside). Ashtray is flatter, not near as much "puff" to the sheetmetal. Sharpie
09-07-2010, 03:29 AM | #14 | |
Re: unigue to 67'
They must be original... I know the PO would never have spent a dime on fancy parts. Instead of a passenger side hood hinge, he had a hillbilly stick to hold the hood up. Someone once painted the truck with Kool-Kote roofing paint.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-07-2010 at 03:35 AM. |
09-05-2010, 10:12 PM | #15 |
Re: unigue to 67'
I believe the jack and accesory storage is specific to 67. All under the seat instead of accesories in the cab corner. Sharpie
05-12-2011, 05:32 PM | #16 |
Re: unigue to 67'
My 67 has the jack in the cab corner, the rest of the pieces are under the seat right on front of the fuel tank. All the other stuff mentioned I have found out except the ignition switch not having an ACC position (wanna guess what I'm doing at the end of today when I drive the truck). My truck has the silver faced heater controls (not too sure they are original though). To be honest the major pieces of my truck are still 1967 but it started life as a 292 4 speed and was combined with a 1971 in later life to become a 350 / 350TH with disc brakes and 5 lugs (3.08 ratio too so the rear axle was swapped). They even swapped out the steering column to get the shifter. So I have a high hump V8 automatic disc brakes which just confuses the heck out of people.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
09-05-2010, 10:23 PM | #17 |
Junior Member
Re: unigue to 67'
Frame is not dimpled for steering box.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-05-2010, 10:56 PM | #18 |
Re: unigue to 67'
67 only GMC tidbits. Only year with GMC on the grill and no adjustment access on the headlight bezels. Sharpie
09-06-2010, 03:11 AM | #19 |
Re: unigue to 67'
'67s have parking lights that go out when you pull the Lights knob all the way out. The glove box door is flat black. '67 K/10s use "Power Assist Steering" --and only rarely-- with a hydraulic ram assisting the manual gearbox. The vent window latches are a holdover from the "Task Force" '60/'66s. K/10 front brake drums (on closed knuckle Corp front end} are very rare, hard to get, and expensive when you find them.
09-06-2010, 10:22 AM | #20 | |
Re: unigue to 67'
09-06-2010, 11:15 AM | #21 |
Re: unigue to 67'
when did the emergency/parking brake handle change? I had a '68 so long ago I can't remember.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
09-07-2010, 03:41 AM | #22 |
Re: unigue to 67'
That was my first reaction, too. I had to stop a guy wth a '67 stepside and ask him about it, and then check it out his light function, until I believed it. Obviously this was before we had this forum.
09-07-2010, 04:13 AM | #23 |
Re: unigue to 67'
great thread. im about 100% sure that all 67s were painted a silver looking color on the inside, reguardless of exterior color.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
09-07-2010, 06:03 AM | #24 |
Re: unigue to 67'
Here is my 67, the interior is a different blue than the exterior color.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 09-07-2010 at 04:44 PM. |
09-08-2010, 06:39 AM | #25 |
Re: unigue to 67'
I'm not sure that the "silver-looking color" was in all the trucks, but I have a '67 Suburban and a '68 C/10 stepside that use that interior color. Both trucks were built at Fremont, Calif. Incidently it was called "Fawn" or Silver Fawn Irridescent. Year One and/or Paddock Parts carry it in spraycans.
