Old 09-07-2010, 12:31 AM   #1
76/85 Truck
76/85 Truck's Avatar
NP203 Help
Thanks for all who are reading! When I first started researching my 203, I thought maybe I had a model without the "lock" option. I crawled underneath it and i have 2 plates sticking out of the bottom of my shifter tower. when i have someone cycle it from Hi to Lo, the plate on the passenger side goes forward and back, and the plate on the drivers side TRIES to move more forward, but it looks to me like it is all the way forward it can go, so consequently, it won't go into "Lock". I took the linkage off the plate, and i can pull the linkage toward the front of the truck, and I hear a "clunk" and it goes in "Lock". So, I am guessing, my shifter mechanism is seized. But, it looks to me like the plate for the Lock is supposed to go back. Would someone please let me know which way the driver side plate moves when you put it in "Lock"? And if it indeed does move even more forward, should i just take the tower off and take it apart and lube it up? Thanks and sorry for the long post!!
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 09-07-2010, 12:36 AM   #2
76/85 Truck
Re: NP203 Help
Which way does this driver "plate" move when engaged in lock? It LOOKS like it already all the way forward, but the LOCK linkage only moves a small amount (about an inch toward the front of the truck) so does that plate or "Fork" go even further forward? THANKS a BUNCH!
Rich
Old 09-07-2010, 02:32 PM   #3
mokelife77
mokelife77's Avatar
Re: NP203 Help
what is the lock for?
way2fonky
mokelife77 is offline   Reply With Quote
Old 09-07-2010, 02:47 PM   #4
Adams74Chevy
Adams74Chevy's Avatar
Re: NP203 Help
The lock on NP203s is for low traction situations it sends the power evenly to the front and back, while when not in lock it will still send power to both front and back but if wheels start slipping more power goes those slipping.
I'm not much help on the linkage, but I plan on cleaning mine up and possiblely making it a twin stick to help alleveate the issues these shifter/linkage are known for.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 09-07-2010, 07:41 PM   #5
LONGHAIR
Re: NP203 Help
It is a funny "clock works" inside there, but opening it up and cleaning/re-lubing helps a ton.
The lever that works the "hi and low" ranges moves foreward and backward from the neutral position. But, the lever that moves the "lock" only moves one way. This is why the crazy spring works is inside the housing.
The typical mud and grit that a 4 wheel drive truck gets into is exactly what these shifters don't need.....
I have never seen one "wear-out" or even break (internally). I have seen quite a few with the mounting bracket cracked. I can only assume from abuse, when a clean-up and adjustment would have fixed it.
There is a hole through the middle of the housing and levers that "centers" everything for the adjustment. Push a drill bit through this hole, aligning all of the levers, then adjust the length of the connecting rods to fit.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-07-2010, 09:42 PM   #6
76/85 Truck
Re: NP203 Help
Thanks! I'll have to take it apart this weekend and grease everything. So that case comes apart that holds all the inter workings?
Rich
203, 76 chevy, np203
