Old 09-07-2010, 05:15 PM   #1
kauaiman
Turn signal help
Have a 1962 fleet side and was wondering where the turn signal wiring block is suppose to be located. Mine is obviously under the dash on the steering column,but is it suppose to be on top of the column or below it. I see no screw holes anywhere on my lower column. If you have a 1960-1962 this should make some sense,I hope. Thanks for any info
kauaiman is offline   Reply With Quote
Old 09-08-2010, 12:56 PM   #2
jku72
Re: Turn signal help
I'm replacing mine now too. Mine attaches to the lower right side of the column. The screws are off set. Held on by two screws.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 09-08-2010, 06:13 PM   #3
kauaiman
Thanks for the info, do you know how the steel wire attaches to the turn signal switch? Mine fell off .
Old 09-09-2010, 08:15 AM   #4
jku72
The wire clips into the switch. My new switch is different than the original, but the new one still clips in.
68 C10 burb
42 Willys MB
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
