![]() Join Date: Aug 2010
Air Bag switches
I'm in process right now of completing my air bag suspension.
I plan on doing just front and back, no side to side. I have everything set up as the front sit on the ground, though the rear still needs to be notched to be as low but for right now it works. I need some idea of how to mount the switches or do a box for them. Any ideas |
Redefining LowBudget
Re: Air Bag switches
not sure what year truck....
I have mine in the concol but I have the guages mounted into a radio delete panel..if I didn't have the consol I would have mounted the switches in the knob holes.....I just didn't want to cut the dash and it all fit nicely |
DiablosWeldingFabrication
Here is mine!
Happy to be here
![]() Join Date: Mar 2000
What we did on my 77
Hollister, CA.
![]() Join Date: Sep 2006
"OLD SCHOOL" .....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
mine are behind where the ash tray was.
you will need a sway bar too if not running 4 switches. trust me
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
Thanks guys,
GGInferno where did you find that gauge setup on the left that shows the oil pressure and such? All I'm running is 1 switch, power the compressor. 1 for front/ up/down, 1 for rear/ up/down, 1 for all up/down Its on a 63 longbed |
C10 CLUB Y QUE!
another
Happy to be here
Your going to hate the side to side air transfer with that set up. May as well do it right the first time.
Registered Loser
You can go with your 3 switches and eliminate the side to side roll by running 8 valves, a fill and a dump for each bag. That's how I'm doing mine.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
[QUOTE=ANoodle;4179877]Thanks guys,
GGInferno where did you find that gauge setup on the left that shows the oil pressure and such? All I'm running is 1 switch, power the compressor. 1 for front/ up/down, 1 for rear/ up/down, 1 for all up/down Its on a 63 longbed Summit Racing here is the link! http://www.summitracing.com/parts/SUM-800104/ ![]() |
I'm running 8 values, just hooked all the switches up and we are good to go.
All that needs to be done now is the air compressor being hook up and making a cover for it. Dont want it to get rained on or anything like that. Might even put in another battery so I know I have the power......Hahah |
