Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-07-2010, 09:23 PM   #1
dammitmitchell
the pollock
dammitmitchell's Avatar
lets talk performance
OK gents!
So i was going to put a new stock motor in my 98 2wd blazer with a 4.3..
but a firend of mine REALLLLY wants it. BUT he dosent want the stock motor.
so we negotiated a deal but he wants me to build him a screaming little
motor. maby 300 hp if plausable.
But the issue to me is that the motors bad because the PO had ran it avter overheating and it has no compression now.
im worried that if i pull the block down the walls wont be serviceable.
Do you guys think this is worth the time and effort?
Also what has been commonly done and proven worth while for a build?
I personally ahve been thinking repair cyl walls, get a different piston to bring up the compression and a mild cam.
exhaust and intake also.
whats your input?
thanks!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-07-2010, 09:48 PM   #2
kdhs10
kdhs10's Avatar
Re: lets talk performance
Just put a 350 in it, would end up cheaper.
kdhs10 is offline   Reply With Quote
Old 09-08-2010, 02:32 PM   #3
dammitmitchell
the pollock
can it fit? do you have a link to a build for it?
ive been told a 350 vortec wouldnt fit....
Army vet 02-08
Old 09-08-2010, 03:19 PM   #4
kdhs10
kdhs10's Avatar
S10forum.com has an entire V8 section, and an LSX section. Go check it out.
Old 09-08-2010, 07:38 PM   #5
dammitmitchell
the pollock
thanks!
Army vet 02-08
Old 09-09-2010, 09:54 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
doesn't Whipple have a roots type blower that fits these CSFI Vortecs? that should get him close to or past 300 HP.
for what the parts cost I wouldn't bother building a 4.3. a Goodwrench reman goes for about $2100
68C15 is offline   Reply With Quote
Old 09-10-2010, 10:12 AM   #7
kdhs10
kdhs10's Avatar
That could work as well, a friend of mine had a blower on his 98 SS and was putting 290hp to the wheels. He has an LT1 now though, .
Old 09-10-2010, 02:00 PM   #8
thirdstreettito
Resident of Here
thirdstreettito's Avatar
http://www.wynjammer.com/ALM1115/GM_S10_4_3__V6.html
http://www.speedomotive.com/ps-505-8...roker-kit.aspx
Do both and it will SCREAM!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-10-2010, 08:26 PM   #9
BarryB
BarryB's Avatar
I've seen these things with BBC in them, so it'll fit. The only difference in size between the 4.3 and a 350 would be the 350 is longer. I'd go for the v8 swap in my opinion. cheaper unless your friend wants to spend a fortune on it.
wonder if you could get a cyclone,or typhoon set up for it?
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-12-2010, 08:27 AM   #10
kdhs10
kdhs10's Avatar
Talk about expensive, if you can find them they are worth their weight in gold, at least the sellers think so anyway.
Old 09-12-2010, 12:48 PM   #11
Arad68
Trucks N Tranzams
Arad68's Avatar
I agree with 68C15 on the Goodwrench reman if you decide to go with the V6.
I have a 2002 Extended cab with a 4.3 and a 5 speed, it's really cool, but not V8 cool.
A non elaborate 5.3/4l60e swap would be bone stock fun and still yield excellent fuel economy and 300hp for roughly the same price. I plan on a V8 swap for my S10 and will probably end up with this or and LS1/T56 swap.
Check out these links. They top my list in all the research I've done on this.
http://www.s10forum.com/forum/lsx-discussion/
http://www.currentperformance.com/s10wir.html
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
