Old 09-21-2010, 01:48 AM   #1
'72customdeluxe
In-rad. trans cooler question
Being away from my trck right now, could anyone tell me whether the trans lines going into the radiator exit from the top or bottom? I'm trying to plan out a secondary external cooler
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 09-21-2010, 01:53 AM   #2
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: In-rad. trans cooler question
top is in and bottom is out
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 09-21-2010, 01:56 AM   #3
'72customdeluxe
thank you sir
Old 09-21-2010, 02:23 AM   #4
'72customdeluxe
Also, do you know the fitting sizes?
Old 09-21-2010, 11:34 AM   #5
tqlspec
tqlspec's Avatar
I believe the fittings are 5/16 flare (1/2 - 20 thread). Someone correct me if I'm wrong.
Retired Navy
1972 C10 Cheyenne fleetside
350 sbc, 700r4, 3.42 rear
tqlspec is offline   Reply With Quote
Old 09-21-2010, 10:51 PM   #6
'72customdeluxe
I was worried when I saw the metal plate in the middle behind the grill shell (forgot that detail), but turns out there's plenty of room for a 40k gvw cooler on the back of the condenser and it makes the hose routing even cleaner. sweeet. SHould keep a 3k stall happy
Old 09-21-2010, 11:51 PM   #7
PipsC10
PipsC10's Avatar
that is correct, I just had to order some
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
