Old 09-26-2010, 12:34 AM   #1
Ronnny
won't start when hot
My 68 long bed has a 350 with a 400 tranny. It has the points from the first motor it had. The truck starts and runs fine. If you cut the motor off it will start right back up. But if you turn it off long enough to get gas or run into a store it will not restart. It does run good. i was told maybe the coil but have not swapped it out yet to see. I plan on putting in a hei dist. soon. the carb runs fine and i do not think it is the choke but could be wrong. If i cut it off i can start right back up. But if i let it set 5 minutes it needs to go ahead and set a another 10 or so. any other ideas?
Ronnny is offline   Reply With Quote
Old 09-26-2010, 12:53 AM   #2
eastcoastcivil
Re: won't start when hot
My 67 used to do the same thing only it wouldn't start back up right away like yours. Turned out the starter was getting too hot because of the headers and the solenoid was becoming heat sinked (the magnet wouldn't work until cooled). I just put a heat shield on the headers and that solved the problem. Not sure if that might be your problem but worth a shot.
If your not living for something, your dieing for nothing...
eastcoastcivil is offline   Reply With Quote
Old 09-26-2010, 01:44 AM   #3
swamp rat
swamp rat's Avatar
I agree on the starter getting hot, but you didn't mention if you gad headders or not?
I put a set of Doug Thorley Try Y's on my 350 after i built it and i had the same problem, the starter was getting hot as the lack of airflow when i shut it off was too hot for it. I had to wire up a ford style starter Bendex on my passenger fender wall
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-26-2010, 01:53 AM   #4
nyncompute
nyncompute's Avatar
Just to clarify.. will it crank freely, i.e. drag from the starter when warm, or just crank and crank and not fire up.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 09-26-2010, 01:57 AM   #5
CCCC
CCCC's Avatar
The above posts are good - may identify your problem - but also have had a couple of engines that did something similar because the lack of air circulation when first sitting enabled engine heat to vaporize the fuel at one "hot" spot in the delivery line - so after a short while no fuel flow due to a sort of vapor lock situation. After cooling down, all was OK. So, I bent or moved the line further from the block or put an insulator in between. Just one possibility.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 09-26-2010, 02:13 AM   #6
swamp rat
swamp rat's Avatar
Oh, on my engine the solenoide would just click like i had a dead battery but the battery was fine.....
Hum, maybe possible the coil gets to hot without airflow? Hard tellin for sure, if it was me i'd want to check for spark the next time it does it, do you have one of the in line spark checker lights that you plug into the spark plug wire then onto the plug?
Your float bowl should have enough gas in it to fire up the engine butr you could pull the airfilter and rock the linkage and make sure its squirting gas in the carb. My fuel line is steel and is bolted to the front of the block and up along the intake manafold to the carb never had a fuel vaperization problem from that. But like it was posted be sure to check how close the delivery line from the tank to the pump, and from the pump to the carb are from the exhaust. It couldn't hurt to be looking for rotted hoses and replace them while your at it.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-26-2010, 02:54 AM   #7
pat 70/71
pat 70/71's Avatar
I think this is called (heat soak) starter gets hot& drags/ (long crank) I have this problem with my 71, going to order a mini starter for my truck. starts great when cold. drive it twenty minutes and it will start but, takes a long time to start.( heat from the headers) anywho, good luck hope this helps cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 09-26-2010, 09:06 AM   #8
Shyguy
Junior Member
Shyguy's Avatar
If your engine turns over fine, but does not fire up it is not a problem with the heat soak of the starter.
You did not mention what carb, you have. If it is a Q-jet or Edelbrock the gas may be boiling out of it if it sets for more than a few minutes.
You could put a phenolic spacer under the carb which should prevent boiling of the gas.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-26-2010, 11:15 AM   #9
OKLAHOMAWELDER
Tradin' Fool
I had this problem with a SBC in a toyota 4x4 I had but it had an MSD ignition on it. It would start and run just fine, then when you killed it after driving it, it would not start until it sat and cooled off for a while. We pulled the MSD off of it and never had another problem with it. So, just a thought, maybe check the ignition system....
OKLAHOMAWELDER is offline   Reply With Quote
Old 09-26-2010, 12:00 PM   #10
jcis4me
jcis4me's Avatar
Aloha
Mine did the exact same thing. The fuel line was too close to the exhaust, so I ran new fuel lines (mine are all rubber), along the out side of the frame well along with the electric fuel pump and viola problem solved!
My 2 cents worth!
Aloha
Marty
jcis4me is offline   Reply With Quote
Old 09-26-2010, 12:13 PM   #11
nerve
My 72 does this sometimes...turns over, but won't fire right away...I gotta pin the gas pedal...and then let her rev for a few or she will stall...I think it's the angle of the fuel lines...If I park slanted forward on hill, forget about it...
nerve is offline   Reply With Quote
Old 09-26-2010, 01:59 PM   #12
cdowns
cdowns's Avatar
i agree that phenolic spacers prevent fuel peculation in the carb
another common cause is lazyman rubber fuel lines laying on the manifold or resting on the engine block causing a vapor lock condition, they also in the long run cause nice big fires in the engine compartment
Old 09-26-2010, 03:36 PM   #13
Ronnny
It is not the starter for it turns the motor over no problem until the battery dies. Will look to see next time i drive it if it looks like getting a vapor lock. It is running a tired old q-jet that runs really well. will swap out the coil before i drive it again since i have a few laying around. It is supose to rain the next few days and the wipers do not work. It is on my list to see ifin it is the switch or the motor for the wipers that is broke. I am not into power a lot and thought about this 2 barrel setup my wife's brother in law gave me. Complete from intake to air cleaner.
Old 09-26-2010, 04:29 PM   #14
pat 70/71
pat 70/71's Avatar
I learn something every day (never thought of boiling the fuel) thanks for your response. going to check into a phenolic spacer & make a hard line from the pump to carb (think I could be running a bit lean also) cheers, Pat
Old 09-26-2010, 05:46 PM   #15
turner72
I had the same problem with mine. I had some corrosion on the cap and rotor. Cleaned it off, set the dwell and timing. It has started perfect ever since.
turner72 is offline   Reply With Quote
