09-27-2010, 09:43 PM | #1 |
can any identify this old dana transfer case?
I found this just sitting in the back of a late 60s Ford pick up at the boneyard, but the pick up itself was complete no trans or case missing so I do not want to assume anything.
The case says Dana in a small diamond shape and I found these numbers to the right just above the rear yoke. It has a total of 3 shift levers, one for gear selection and two smaller shift levers off to the passenger side. Thanks for any help. |
09-27-2010, 11:30 PM | #2 |
Re: can any identify this old dana transfer case?
I did a google search and found this webpage, it looks to be it, i have no working knowledge of that model myself..
http://www.novak-adapt.com/knowledge...se_gateway.htm http://www.novak-adapt.com/knowledge/model_18.htm
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 09-28-2010 at 12:55 AM. |
09-28-2010, 12:50 AM | #3 |
Could be a dana / spicer 18. I think they have the front and rear output in line or offset from the input.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-28-2010, 12:51 AM | #4 |
Oops Swamp Rat beat me to it. Sorry
09-28-2010, 11:12 AM | #5 |
Thanks guys,
Hey Swamp Rat, this is a fantastic website, detailed in history and technical data. If you have any more like it let me know, again thank you. |
