Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-30-2010, 10:53 PM   #1
C-10 simplex
What's a good harmonic balancer puller/installer?
i will try the search function as well, but in the meantime what's a decent harmonic balancer puller/installer?
1) When i say decent, i mean one that will basically do the job; i will consider harbor freight type stuff----i won't be using it that often.
2) Also, i'm not sure if i will need a puller to take the timing chain sprocket gear off the crank, so we should take this into consideration also----should i get a puller that can do both?
C-10 simplex is offline   Reply With Quote
Old 10-01-2010, 12:21 AM   #2
ERASER5
ERASER5's Avatar
Re: What's a good harmonic balancer puller/installer?
KD Tools (KD 2286)
http://www.tooltopia.com/kd-tools-2286.aspx
This what I use. Do NOT use a 2, 3,or 4 jaw puller. You will pull the balancer apart and destroy it.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 10-02-2010, 09:40 AM   #3
pat 70/71
pat 70/71's Avatar
Tavia makes a tool for this and it is reasonably priced too if memory serves $26.00 check with Summit/ Jegs cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 10-02-2010, 12:08 PM   #4
cdowns
cdowns's Avatar
the one i've been using for 30years i bought from jcwhitney
Old 10-02-2010, 12:29 PM   #5
msgross
msgross's Avatar
I went to autozone and used theirs for free... go to the desk and look at the placemat with all of the tools for rent. You basically buy them and then return them when you are done, money is fully refunded...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-02-2010, 01:54 PM   #6
cdowns
cdowns's Avatar
the gas money i've saved from trips back and forth to autozone for 30years has more than justified the expence// if i decide at 3AM to pull a balencer i just go to my toolbox a short 10foot trip
Old 10-06-2010, 02:11 PM   #7
faribran
.. what CDowns said... i think thatz where mine came from ... still working well after all these years............. not sure if it will work on the LS engines.. will find out soon
faribran is offline   Reply With Quote
