Old 10-04-2010, 09:17 PM   #1
wavespy
wavespy's Avatar
Is this normal???
I'm taking the pulleys off the crank on my 396 because the don't line up w/ each other (water pump and such) and I was quite surprised to find no less than 5 washers (6 if you count the lock washer) on the center balancer bolt! Is this normal, or did some previous owner/mechanic jack things up?!?!
'69 C20 396
Cameron
wavespy is offline   Reply With Quote
Old 10-04-2010, 09:22 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Is this normal???
Everything that I have worked on, has had one large flat washer.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-04-2010, 09:25 PM   #3
71swb4x4
71swb4x4's Avatar
Can't help you, but I find it amusing that I just finished a Fat Tire and then sat down at the computer to check the board.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-04-2010, 09:31 PM   #4
Dark Knight
Dark Knight's Avatar
Maybe someone was too lazy to go to the store and buy a replacement bolt for the one that they just lost, so they used what they had. Happens all of the time around the farm. lol
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 10-04-2010, 10:33 PM   #5
geezer#99
geezer#99's Avatar
Take the washers off and see if it screws all the way in and can be torqued down. I suspect the threads are stripped deeper inside the bolt hole.
geezer#99 is online now   Reply With Quote
Old 10-04-2010, 11:44 PM   #6
wavespy
wavespy's Avatar
Yeah, it seemed excessive to me too. The bolt definitely DOES NOT appear to be a GM standard issue bolt. It's a 2.5" long, 1/2" 20 pitch with a 1'' shoulder on it. I think I'll just get a replacement bolt and see what they give me.
It was also barely finger-tight when I got in there!
Cameron
Old 10-04-2010, 11:54 PM   #7
69sixpackbee
That is not the right cap screw, that,s why. Way too long.
69sixpackbee is offline   Reply With Quote
396, balancer, bolt, pulley, washers
