Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 02-28-2003, 08:25 PM   #1
badz28white
Unhappy Driveshaft Needed
I need a complete 2 piece drive shaft for my 1990 GMC Suburban 2wd. I'm told that 87-91 all will fit. Today I pulled one from a buddies 82 and it fit also. I have a very bad vibration problem. Swapped his into mine fixed the problem. He unfortunately insisted I give his back and so I need one badly. Anyone out there have one for sale.
1990 Suburban
94 Z28
92 Corvette
"Boys and their Toys"
http://www.libertyhillwebs.com/JW/
badz28white is offline   Reply With Quote
Old 03-11-2003, 07:10 PM   #2
jeffbo
D.U.F. Member
jeffbo's Avatar
Did you check your u-joints. They could just be bad, and causing your vibration. If so, it is an easy, and fairly cheap fix.
MEMBER OF THE DISCS UP FRONT CLUB
'72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt
'68 C-10 4spd (not running)
'79 C-10 LWB Mild 350
'80 Caprice Classic, 2-dr
'97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto
jeffbo is offline   Reply With Quote
Old 03-12-2003, 05:58 PM   #3
badz28white
Yeah I checked them first, found a driveshaft finally. the rear portion was causing the problem. Replaced the carrier bearing as well. All is good to go now. For that part at least. Thanks for the reply.
1990 Suburban
94 Z28
92 Corvette
