Old 10-18-2010, 10:28 PM   #1
buildinga55
I am looking for a Relay Expert for my AC
I have wired my entire truck and everything is going well. Except I am totally confused about if I need a relay and how to wire it if I do for my AC unit. I have a Southern Air Superfrost unit. By the time you plug in all the pre-wired wires, you have two wires, a red power wire with an in line 20 amp fuse and a black ground wire. All of the switch and thermostat are wired in the switch enclosure. I understand you normally want relays for high power items. Maybe this is not considered high power since it only has a 20 amp fuse, I don't know.
buildinga55 is offline   Reply With Quote
Old 10-19-2010, 09:34 PM   #2
britnjc
britnjc's Avatar
Re: I am looking for a Relay Expert for my AC
take a look at this diagram from vintage air. it tells you how wire a relay in. its how i wired mine.
britnjc is offline   Reply With Quote
relay
