Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-19-2010, 11:28 AM   #1
Bad70sbchevy
Bad70sbchevy's Avatar
Help with Subwoofer rattle
Hey everybody, I was just wondering what to do to keep my sub box from rattling excessively. I know this is just a fact of life when putting subwoofers on an older truck, but I didn't know if putting some kind of insulation between the box and the back panel would help. I just got the box attached to the top of the original gas tank brackets. Thanks
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 10-19-2010, 06:27 PM   #2
tubbedII
needs more $$$
tubbedII's Avatar
Re: Help with Subwoofer rattle
There's all kinds of things you can do for excessive rattle, but first is to determine exactly what is rattling. From there, you can try to eliminate it by removing it or covering it with something. With my first car at 16, I lined the truck outter panels and license plate with old cutup bicycle inner tubes...I didn't know about dynomat, but it worked good enough for a kid with no extra money.
The best bet is to get some type of dynomat (pick your flavor as there's a lot to choose from) and cover the area behind and under the box at least. It would be best to cover the entire floor all the way up the back of the cab, up the firewall, and inside of the doors, but that gets expensive.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-19-2010, 09:40 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
different sounds vibrate parts at different levels,seen expanding foam used inside pillars other places to stop it
maybe some sort of spray bed liner,but i will say the dyno stuff makes for a quiet cab ride with out the radio
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 10-19-2010, 11:19 PM   #4
AceX
>130dB Moderator
AceX's Avatar
Dynamat for the metal bits that rattle. If the box itself is flexing and making noise, then you will need to reinforce the box itself.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
