Old 10-19-2010, 01:54 PM   #1
BIG V
crew cab short bed question????
does anyone have pics on where to cut the suburban frame and where to cut the chevy pickup frame to make the ccsb frame im getting ready to build a frame in the next couple of weekends and was wanting some reference material
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 10-21-2010, 12:03 PM   #2
BIG V
Re: crew cab short bed question????
No one huh?
Old 10-21-2010, 12:37 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Look in the Project and Build section. There are several of them there. They have been the fad for the last year or better.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 10-21-2010, 10:45 PM   #4
phishninmn
check the build thread Tow Me has for his ccsb he used a suburban front and pickup rear frame for his truck
phishninmn is offline   Reply With Quote
Old 10-22-2010, 04:08 AM   #5
BIG V
tow me doesnt have very many pics i cant even get one pic to show up. ive looked in the section there is only one person whos done it with the burban frame... any more help would be appreciated
Old 10-22-2010, 07:19 AM   #6
joe231
joe231's Avatar
tow me did a diagonal cut under the cab where the center cab mount (or second burb body mount) is.
why not just shorten the heavier crew cab frame to accept the short bed?
CHEVY ONLY
Old 10-23-2010, 10:04 PM   #7
BIG V
the crew cab is a 2wd and the suburban is 4wd. i hate the way a bolted on front spring brackets look. i want it to look factory with the factory rivets. plus its going to be my wife's mall crawler it doesnt need the 1ton frame. Thanks for the info on where the cut was, now that the suburban body has been removed i can see where it needs to be cut. Now to get my sb truck frame.
Old 10-23-2010, 11:33 PM   #8
joe231
joe231's Avatar
Gotcha
No problem
CHEVY ONLY
Old 11-02-2010, 04:54 PM   #9
BIG V
what has everyone done with the fuel lines, i'm going to keep the tbi off the 91 burban whats the trick to streching the fuel lines??
Old 11-02-2010, 05:39 PM   #10
joe231
joe231's Avatar
I'm doing the same thing.
burb tank in the rear with the factory in tank pump and fuel lines. The factory fuel lines have a union in the vicinity of the rear axle in the burb. My plan is to go to the parts store and find 3 lines the correct size and 3 unions to fill in the gap. I believe putting the tank in my CCSB has moved the tank back 10-11" so I should be able to get 12" pieces of line to make it work. That is what i plan on doing next weekend. Oh, and I'm also going to have to extend the wiring
CHEVY ONLY
