10-19-2010, 09:56 PM | #1 |
Tire Size Recommendation: 1972 C10
I've got a 1972 C10 with 15x8 Rally wheels with a 4.5" offset. The truck isn't lowered. Right now I've got some 60 Series tires on it that are a little embarassing
What tire size would work well to fill up the wheel wells a bit better but still be somewhat of a performance tire? Thanks! |
10-19-2010, 10:08 PM | #2 |
Re: Tire Size Recommendation: 1972 C10
275 60 15
Fuzzy |
10-19-2010, 10:17 PM | #3 |
Man of Mini-Talents
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
10-19-2010, 11:10 PM | #4 |
i like my 31x10.5s in the rear. the front has 225/70 but will be switching to 225/75s up front.
stock ride height: 3/5 drop: |
10-19-2010, 11:14 PM | #5 |
265 70- 15 Rear
255 70 15 fronts
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot. I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace... 72 short step w/ 388 /4l80e/ and 3.08 gears. Last edited by llowlife; 10-19-2010 at 11:30 PM. |
10-19-2010, 11:51 PM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
275 60 15 x 4
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
10-19-2010, 11:54 PM | #7 |
I have the 275/60 r 15 on my truck with white letters. It looks good the way it is. They are just next to nothing shorter than a 235/75 r 15 I might like just a little narrower though but my tires had the right price when i aquired them.
10-20-2010, 12:24 AM | #8 |
I'll have to take a look; I've got some 60's on there now and they look too low profile to me...
10-20-2010, 12:27 AM | #9 |
10-20-2010, 12:59 AM | #10 |
Junior Member
You need a taller tire. 75 series...
frontstreetcycle on Instagram |
10-20-2010, 03:47 AM | #11 |
71-C10
I have 255/70/15 on 8.5" rims all around, fills out holes nicely. about $75 each>> http://www.experttire.com/catalog/pr...ction?id=68074 235/75/15 = 28.9" 255/70/15 = 29.1" You can compare sizes here>> http://www.rimsntires.com/rt_specs.jsp Last edited by SSedan64; 10-20-2010 at 03:53 AM. Reason: More Info |
10-20-2010, 07:33 AM | #12 |
70+ ( Old Skool Club )
Anyone thought of running 255/70R15's ( they look really good on an 8 inch rim) on a stock height truck? They are pretty much the same height as 235/75R15's but a little wider, about 3/4 of an inch. As soon as my 235/70's wear out that is what I'm going to put on my 15 x 8 Rally wheels.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 10-20-2010 at 07:34 AM. |
10-20-2010, 09:30 AM | #13 |
DON'T TREAD ON ME
255/70 R15 all four corners
Old Yeller Last edited by Old Yeller 1970; 10-20-2010 at 09:31 AM. |
10-20-2010, 12:25 PM | #14 |
10-20-2010, 01:09 PM | #15 |
I run 255 /70's rear on the 8" ralley (nice fit). Up front I have 225/75's on a 6 1/2" van ralley to help with fender clearance on my lowered truck. crazyAL
http://community.webshots.com/user/hotrodhorn |
10-20-2010, 03:15 PM | #16 |
255/70/15 all around ....
350/th350 Sportsman2 heads Performer Intake 1406 carb 3.42 Eaton Posi |
10-20-2010, 07:13 PM | #17 |
DON'T TREAD ON ME
Old Yeller |
10-20-2010, 08:11 PM | #18 |
255/70/15. do not put 75 series tires on your truck. did it, hate it!!!
10-20-2010, 08:37 PM | #19 |
10-20-2010, 08:43 PM | #20 |
235/70/15
Trueman Last edited by 463; 10-20-2010 at 08:44 PM. |
10-21-2010, 07:48 PM | #21 |
sidewalls r to high!! trying to fill the fenderwells with tire is not the way to go at all, u gotta lower the truck. the transmission shifts different, gotta change the speedo gear (possible new leak) and the truck sways all over the road if u don't get the right tire. I put 60 series tires back on it and I plan on lowering it just a little, nothing crazy. 255/70/15 is the way to go or maybe even a 65 series tire I was thinking about today but haven't had time to look them up. gotta have white letters too!!!
10-21-2010, 07:53 PM | #22 |
255/70 in front and 285/70 in rear.....its only lowered 4in in rear and the 285 fills it up well......Diamondback tire and Coker have 285/70s
10-21-2010, 08:40 PM | #23 |
I run 31X10.5X15s all the way around. If I get new tires, I'll go with 32s. Stock height, that's how I roll.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-12-2014, 11:07 AM | #24 |
Will a 295/50/15 fit ???
It's been a long time coming... It's time to get it done.. |
08-12-2014, 12:38 PM | #25 |
Yes
Fuzzy |
