Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-20-2010, 01:33 PM   #1
brans72
Any GM Tech here wiper problem.
Ok quick run down I know pulse boards on a 99 GMC Sonoma! Problem is when I cut my wipers off they will keep working up to 5 mins and sometimes if on low they will start wiping faster!!! I can cut key off and back on then they will stop or I can keep messing with switch and get the wipers to stop after messing with it etc. So what do you think wiper switch?Wipers never come on at radom just mess up when there on or trying to cut off. Any actual way to test it? Thanks Brandon
brans72 is offline   Reply With Quote
Old 10-20-2010, 01:36 PM   #2
dmwphoto
dmwphoto's Avatar
Re: Any GM Tech here wiper problem.
sounds like the switch to me. I am sure there is a way to hook a meter to it but could not begin to describe how. I would have to be there.
dmwphoto is offline   Reply With Quote
Old 10-20-2010, 01:38 PM   #3
ofnaman
ofnaman's Avatar
There is a way to test, but you will need alldata or some sort of repair information to find the correct terminals to check. Like you said, the circuit boards are an issue with those trucks and it will cause that problem. Im trying to pull up the info right now for you, but our gm service info is down at the moment.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 10-20-2010, 01:45 PM   #4
ofnaman
ofnaman's Avatar
Another thing to try is to get some electronics cleaner and spray some in the wiper switch and work it in. Also, if you can get it to act up, tap on the wiper module with a screwdriver end. Usually if the module is bad, tapping on it will make it do something different.
