Old 10-22-2010, 07:41 PM   #1
1LowToy
Short bed to Blazer?
Here's the question. Will a Blazer body fit onto a short bed 2WD frame?
Reason I'm asking is I may have the oportunity to pick up a 73 short bed with a real poor body. I know there are numerous Blazers tht are parked due to smog problems here in California. Maybe I can put the two together and have a 2wd Blazer with a smog free chassis?
1LowToy is offline   Reply With Quote
Old 10-22-2010, 07:59 PM   #2
baclay9
Re: Short bed to Blazer?
It would be titled whatever year the body was. It carries the vin.
baclay9 is offline   Reply With Quote
Old 10-22-2010, 08:11 PM   #3
1LowToy
Things are done a little different here.
Old 10-22-2010, 08:30 PM   #4
f.monroe
f.monroe's Avatar
The floor pans are different between trucks and blazers. The wheel bse is shorter on a Blazer than a short wheel base truck also so I say no it wont work .
Not without cutting the frame at the minimum.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-22-2010, 09:50 PM   #5
menace121978
menace121978's Avatar
maybe you could explain this statement in a little more detail
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-23-2010, 12:14 AM   #6
LiveAnimals
LiveAnimals's Avatar
A lot of things may be different in CA. A vehicle is always registered according to the vin on the body.
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 10-25-2010, 01:16 AM   #7
slider
my truck started out as an 85, cracked frame, ment a frame replacement with a 75 frame and title, using the 85 body and bed, dmv titled it as a 75 because of the frame numbers
slider is offline   Reply With Quote
Old 10-25-2010, 07:42 AM   #8
menace121978
wow! i've never heard of that... did you have to swap vin tags on the cab then?
"Dennis the Menace"
Old 10-25-2010, 10:59 AM   #9
sandnuriz
sandnuriz's Avatar
Wow that's great
Please let us know
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 10-25-2010, 11:09 AM   #10
slider
yes, the 75 vin tag is in the door, and the 85 vin is gone, the PO did the swap, he's a friend of mine, I know it went to the dmv for verification, and they mached the vin to the frame. and the frame numbers were the key to it being titled as a 75.
