Old 10-23-2010, 11:47 PM   #1
KC_Goose
Barn door / Tailgate Hatch Help
I have a 68' Panel Truck that has the barn doors on it and i really like the tailgate and hatch better. is it possible to switch the barn doors over and does anyone know how much would be involved..
thanks
KC_Goose is offline   Reply With Quote
Old 10-24-2010, 10:24 AM   #2
sharpie1972
Re: Barn door / Tailgate Hatch Help
All of the suburbans have the provisions for either set-up. I'm assuming panels would too. A picture would confirm that. You should have empty slots for hinges top and bottom filled with rubber plugs if it does. Your best bet is to find a donor with every piece you need or someone who is willing to strip everything and ship. Then it's just a matter of bolting the pieces on. Sharpie
sharpie1972 is offline   Reply With Quote
Old 10-24-2010, 02:56 PM   #3
KC_Goose
Sharpie
Thanks for the info. I will check it out
Old 10-24-2010, 05:56 PM   #4
rsavage
rsavage's Avatar
I have a 70 Burb with Barn Doors. I also have a hatch and tailgate I was planning to install in lieu of the barn doors. However, the sill plate and the header plate do not have the slotted provisions for the hinges on the gates. I don't believe that the sill and header are bolt in pieces, at least it doesn't look like it to me. It looks like there are plates in the side jams for the lifts and latches, but I believe you will be stymied by the header and sill.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-25-2010, 01:00 AM   #5
sharpie1972
rsavage might be right. I have a burb with barn doors.... but it was converted from a hatch. Might be able to go that way, but not the other way???? Sharpie
Old 10-25-2010, 01:06 PM   #6
Hart_Rod
Hart_Rod's Avatar
Rsavage is correct. However that sill pieces is bolt in and you can swap one from a tailgate burb.
Hart_Rod is offline   Reply With Quote
Old 10-25-2010, 05:40 PM   #7
KC_Goose
I just checked out my panel and there are not any provisions for the hatch and tailgate. The upper head peice looks to be bolted in but the lower sill plate seems to be welded in place. Hopefully I can find a decent set of header and sill peices when I find a tailgate and hatch.
Old 10-25-2010, 06:29 PM   #8
CharlieBrown
CharlieBrown's Avatar
If it came with a hatch/tailgate..then there are knockouts for the barn doors
if it came with barn doors there are no blanks for the tailgate/hatch
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 10-26-2010, 12:36 AM   #9
KC_Goose
Thanks for the help guys..Now its time for me to find a decent gate and hatch and work on the conversion..
Old 10-26-2010, 12:54 AM   #10
sharpie1972
The lower piece is bolted in, but.... it's large and a little complicated to get out. I cut the frame rails to drop it out the bottom of a parts burb. If yours is still on the frame you may have to lift the body up to get it out. Sharpie
