10-24-2010, 01:00 PM | #1 |
van ralleys
curious if anybody has used the 6.5. my problem is i have 3" belltech spindles and 3" drop springs and now my control arm sits on my inner lip of the wheel. dont really want to cut on the arm if i dont have to. Thanks
10-24-2010, 01:31 PM | #2 |
Re: van ralleys
i have them on my truck with 2.5 spindles and one coil cut i had to shave the control arm a bit
10-24-2010, 01:37 PM | #3 |
Re: van ralleys
do u happen to have any pics and was it the whole bend off the bottom. i bought 1" spacers but it moved the wheel out way to far now it kinda looks weird. o yeah thats with the stock ralleys
10-24-2010, 01:48 PM | #4 |
Getting Old; Going Broke
Re: van ralleys
I used some 15x6.5's on my trailer, does that help?
I think Joe put some on the front of his crew to help with clearance issues. Not totally sure of his drop, but you can probably find out in his build thread. http://67-72chevytrucks.com/vboard/s...d.php?t=383701
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
10-24-2010, 01:56 PM | #5 |
Re: van ralleys
not my pic but i found it on here this is what i trimmed off mine
10-24-2010, 02:13 PM | #6 |
Re: van ralleys
thanks 4 the pic
10-24-2010, 03:29 PM | #7 |
Re: van ralleys
10-24-2010, 10:22 PM | #8 |
Re: van ralleys
Trim the edge of the a-arm lip off using a cut-off wheel on an angle grinder. I drill a hole where I want the trimmed portion to 'end' & cut to the hole. I then use a grinding disc to smooth all the edges completely. No sharp edges = less opportunity for stress cracks.
10-24-2010, 10:40 PM | #9 |
Re: van ralleys
I have 3" spindles and 6.5" van rallies.
my arms are trimmed like the pic above
CHEVY ONLY |
