Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-25-2010, 04:28 PM   #1
bigvinnie
bigvinnie's Avatar
98 S-10 2.2 wiring diagram
Longshot but I got a buddy who doesn't have the factory shop manual and needs to trouble shoot a problem with his fuel pump and associated wiring. The haynes and chilton manuals he has only show an earlier model diagram and his is different with regard to relays, etc.... no power to the pump and the relay appears to work fine as he's swapped it with the headlight relay and the headlights work fine with it... he's also done other tests but needs the wiring diagram to pinpoint the problem.
Does anyone have or can post a wiring diagram for this model truck..?? It's his only ride and he's needing to get to work and back.
Thanks for any help or suggestions.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 10-25-2010, 05:55 PM   #2
clinebarger
Re: 98 S-10 2.2 wiring diagram
This is as big as I can get it, The site resizes the pic for some reason.
clinebarger is offline   Reply With Quote
Old 10-25-2010, 07:30 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can find wiring diagrams at www.autozone.com. You have to register to see the maintenance section.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
