Steering Column
I have a tilt steering column that wobbels all over the place... was wondering if I could get some info on fixing it.
Thanks |
Getting Old; Going Broke
Re: Steering Column
Google "GM column wobble" and you'll find 100's of pages on how to fix it. Boils down to some bolts way down inside the column that have worked loose.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
Re: Steering Column
This thread should have all the info/links you need. I'll be doing this in the near future as mine has a slight wobble.
http://67-72chevytrucks.com/vboard/s...d.php?t=421008
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
Re: Steering Column
Thanks for your help. That information was perfect.
![]() Join Date: Feb 2010
Re: Steering Column
I'm a lazy sack o wet mice. I bought a rebuilt one on flea bay.
Re: Steering Column
I used this same procedure to tighten up my column last year, added a touch of locktite to the loosened bolts. Tried to do it without the pivot pin tool, mistake. I bought one and it did the job. Take your time, lay everything out, clean and lube on reassembly.
Good Luck.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73 '01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10 |
