Old 10-26-2010, 07:00 PM   #1
BIGJWEAVER
BIGJWEAVER's Avatar
91 burb window motor
Anyone ever change a window motor on a 91 burb. , whats the steps already got panal off...THANKX
87 1 Ton Dually LWB 4X4..350 TBI..SM465..205 Tranfer
"MASH ON IT"
BIGJWEAVER is offline   Reply With Quote
Old 10-26-2010, 08:30 PM   #2
48cj2a
48cj2a's Avatar
Re: 91 burb window motor
Remove the two nuts and two bolts that retain the regulator to the door.
Work the rollers out of the channel and then remove the window and secure in a safe place.
Rotate the regulator so that you can access the connector and then the bolts that retain the motor to the regulator.
clean and regrease the rollers, pivot points, and gear portion of the regulator
reverse everything and try not to grease up the window too bad
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 10-26-2010, 09:15 PM   #3
BIGJWEAVER
BIGJWEAVER's Avatar
Thank you so much, someone was telling me maybe on a older style there was a spring in there that would hurt you if it came apart the wrong way.... ever heard of this?
"MASH ON IT"
Old 10-26-2010, 09:27 PM   #4
48cj2a
48cj2a's Avatar
I believe the deadly spring is inside the motor...do not disassemble the motor itself without safety in mind.
03 Suburban Z71 Z71
Old 10-26-2010, 09:28 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Yep they're spring loaded alrighty. Tightens up when you roll the window down and relaxes when you roll the glass up.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-13-2010, 08:15 AM   #6
Mkcustums
Mkcustums's Avatar
If you are replacing it cause it is so weak, maybe get one from an older Suburban. My '80 power windows roll up in about 2-3 seconds. It gets lots of comments about how fast they are, all 4 work the same, perfect! The '86 and '91, not so good. Just don't get your fingers in the way.
Mkcustums is offline   Reply With Quote
