Old 10-27-2010, 04:18 PM   #1
57HotTruck
57HotTruck's Avatar
57 Truck with a Danish touch
Welcome to this thread. After surfing around on this site for some months, it's time to open a thread myself.
I will try to put photos in, as something is happening with the project.
I bought the truck in Germany in 2006. I've been running it for a few years.
But now I want to tear it apart and build it up again.
I've got it sandblasted, and there is some rust on it.
There will probably be some time before anything happens again because I need a place to put my other car before I get started with the grinding and welding.
57HotTruck is offline   Reply With Quote
Old 10-27-2010, 05:45 PM   #2
sgtusmc
sgtusmc's Avatar
Re: 57 Truck with a Danish touch
Very nice truck. I have to ask...is that grass growing on the roof of that house?
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 10-27-2010, 07:04 PM   #3
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Very nice truck and I was wondering the same if that was grass.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 10-27-2010, 07:06 PM   #4
57HotTruck
57HotTruck's Avatar
Funny question.
The roof is made of straw, and it is moss growing on it. it's probably because there are many tall trees around the house.
much shade is equal moss.
Many houses were built like that in the old days, it will last approximately 50 to 60 years. without moss
Old 10-27-2010, 09:52 PM   #5
vjjack04
vjjack04's Avatar
Cool truck and pin striping. I enjoy seeing and old Chevy truck in Europe. Not many like than in Denmark....
vjjack04 is offline   Reply With Quote
Old 10-27-2010, 11:41 PM   #6
Kim57
Kim57's Avatar
welcome to the board.
Cool looking truck.
Kim
Kim57 is offline   Reply With Quote
Old 10-28-2010, 12:35 AM   #7
bobinbc
bobinbc's Avatar
Welcome and nice truck ! Good choice on the year (I'm not biased in any way)
Very nice striping lines, do you have any more pics of the coupe(or roadster)?
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 10-28-2010, 01:00 PM   #8
57HotTruck
57HotTruck's Avatar
Thanks to you all.
You have a good eye there bobinbc. See more at my cardomain
Old 10-29-2010, 08:37 PM   #9
57HotTruck
57HotTruck's Avatar
Just a few photos of the rusty cab.
Old 10-29-2010, 09:18 PM   #10
vjjack04
vjjack04's Avatar
Originally Posted by 57HotTruck View Post
Just a few pny hotos of the rusty cab.
Hey man,
My name is Johnny (from Southern AZ). Let me know if you need parts or info you can't get from the states here. I will help. I know how logistically, problems can exist from the states to Europe. I lived about 7 years in Germany. (was in the US Army). I have a guy locally, getting rid of alot of stock parts. Also, I can recommend a couple places to get stuff from that are reliable - Scott's Hot Rods, and Wild West Rods and Customs.
Old 10-29-2010, 10:27 PM   #11
OrrieG
OrrieG's Avatar
Make sure you brace up the cab good. With the amount of work you are doing it could be easy to get the cowl and back corners out of alignment with the door, especially if you are replacing the steps. Worth the effort to tack, hang the doors to check fit, then do final welding.
OrrieG is offline   Reply With Quote
Old 10-30-2010, 05:29 AM   #12
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Welcome aboard! I'm partial to the 57 as well. Looking forward to seeing it come toogether!
ChuckDriver is offline   Reply With Quote
Old 10-30-2010, 03:17 PM   #13
57HotTruck
57HotTruck's Avatar
Hello OrrieG.
Thanks for your post. It's something I have in my mind. not to cut too much off at once. but I'm a little unsure. where to start. I guess I'll start with the door hinge pillar panel and the outer hinge pillar pocket. hang the door and Adjusting the gaps, and then swap the door step and finally the cab corner. does that sounds completely wrong?.
Hey Johnny.
Thanks for your offer to help. It's actually become very easy to shop over seas, thanks to the Internet.
I have an account with a shipping firm in Virginia which organize all the papers to the Customs.
It was something else, 20 years ago when I bought my first American car. A 63 Pontiac Grand Prix 2 door hardtop. Then you had to, know someone who knew someone who had a cousin who had once been in the usa. something like that.
Old 10-30-2010, 03:49 PM   #14
OrrieG
OrrieG's Avatar
I would look at the order of assembly in the Factory Assembly Manual. My recollection is that the step went in first with the floor, hinge and corners spot welded over the step. I would spot weld in braces to keep the hinge and door jamb pieces in allignment. Then do the hinge pockets so you have something solid to mount the doors on for trial fitting. Then drill out the spot welds in the step, remove it and replace the step first. I would also do the floor cowl area at the same time. I would check the alignment of the door bottom to the step to make sure they are parallel. Then do the rear cab corner. My steps were ok so I just had to deal with the lower hinge and cab corner. The hinges were only rusted thru at the bottoms so I did not have to remove any attachments to the step which kept the alignment.
Old 10-30-2010, 05:08 PM   #15
57HotTruck
57HotTruck's Avatar
Thanks OrrieG.
That sounds sensible. I look forward to getting started.
Old 04-15-2011, 02:52 PM   #16
57HotTruck
57HotTruck's Avatar
I got started with welding.
Old 04-15-2011, 02:59 PM   #17
57HotTruck
57HotTruck's Avatar
more welding.
Old 04-15-2011, 03:07 PM   #18
57HotTruck
57HotTruck's Avatar
more welding.
Old 04-15-2011, 03:20 PM   #19
57HotTruck
57HotTruck's Avatar
The frame is made ​​ready for sandblasting
Old 04-15-2011, 05:10 PM   #20
Kim57
Kim57's Avatar
Looking good. Looks like you got quite a bit done on it.
Kim
Old 04-15-2011, 06:00 PM   #21
flatbed51
flatbed51's Avatar
Ovations!!! Glad to see a Dane on the site. I Have an adopted daughter from Denmark. She will be coming to spend some time here this summer, I will mark your build thread and show her. Keep up the good work. Don
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 04-16-2011, 02:21 PM   #22
1956chevtruck
1956chevtruck's Avatar
Thanks OrrieG.
Well it looks like you got started in a big way! Looks awesome, I like 57's also, call me if you run into any problems.
Byron
1956chevtruck is offline   Reply With Quote
Old 05-14-2011, 04:59 PM   #23
57HotTruck
57HotTruck's Avatar
So I finally got, my frame back from sandblasting. and got it painted with epoxy primer.
Old 05-14-2011, 05:07 PM   #24
57HotTruck
57HotTruck's Avatar
The engine has also been painted-
Old 05-14-2011, 06:17 PM   #25
STEVE60
Good looking work, I to am partial to the '57. I'm jumping ahead, you using a Mustang II IFS.
Steve
STEVE60 is offline   Reply With Quote
