Old 10-29-2010, 12:25 AM   #1
lsp1369
Just bought a 73 c10
I just bought a 73 2wd c10 lwb, got it for $1000, not too bad considering the prices that trucks are going for in cali lately. it has a 350, th400, and a 10-bolt rear end. the color is hideous, but some sanding and primer is going to fix that in the near future. ill be sure to put up some before pictures.
Im just curious what ideas you guys have for any easy power/performance options. I would like to swap heads and cam, it runs really well, i think the bottom end is pretty solid so most of my engine mods will be up top. any info on simple fixes/power upgrades would be appreciated.
id also like to lift it a little, nothing crazy just 4" at most. any ideas on how to go about it would also be appreciated, i understand that in order to do most of the aftermarket spindle lift kits you have to swap for 88+ control arms.. is that correct?
thanks in advance
Lee
lsp1369 is offline   Reply With Quote
Old 10-29-2010, 12:40 AM   #2
nbpro
Re: Just bought a 73 c10
welcome to the site. congrats on the buy. have any pics?
nbpro is offline   Reply With Quote
Old 10-29-2010, 12:46 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
this was a friends truck it had a 3" body lift and 1 ton coils 235/85-16s
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-29-2010, 03:22 PM   #4
lsp1369
Here's some pictures, I told you guys, the color is awful.. this will be one of my first fixes.
Old 10-29-2010, 03:24 PM   #5
lsp1369
and here are a couple pictures of the engine.. its a 350, it looks pretty bad.. but it runs strong.. im in the process of getting a new carb, the fuel filter cover was stripped out..
Old 10-29-2010, 03:39 PM   #6
Pop's C-10
Pop's C-10's Avatar
welcome & i dig tha color
Pop's C-10 is offline   Reply With Quote
Old 10-29-2010, 03:54 PM   #7
OleBlue79
OleBlue79's Avatar
Why replace the Q-jet? That's one of the best carbs ever built. IMO.
79 C-20 Scottsdale 350/400 3:73 gears 9 leafs and a headache rack (I speak English, thank you)
OleBlue79 is offline   Reply With Quote
Old 10-29-2010, 03:56 PM   #8
OleBlue79
OleBlue79's Avatar
That spacer on the carb is off of a TBI engine. I think a 6 banger. Leave it for sure. I put one on my 79 with the 350 and it helped out on the power. I would definantely put an open element air cleaner with a K&N filter.
Old 10-29-2010, 04:40 PM   #9
SS Delux
SS Delux's Avatar
I personally love that green, kinda like a 70 camaro. What are the brackets welded to the bed for ? Is it 2 or 4 wheel drive ? if it is 2 wheel why raise it ?
SS Delux is offline   Reply With Quote
Old 10-29-2010, 06:35 PM   #10
Davidmichael
Davidmichael's Avatar
not bad. welcome
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 10-29-2010, 07:08 PM   #11
sixshooter798
Desert Rat
sixshooter798's Avatar
Its a 73 so its smog exempt. I'd deal with an ugly color for no more smog!
sixshooter798 is offline   Reply With Quote
Old 10-29-2010, 07:30 PM   #12
lsp1369
Oleblue79- I plan on keeping the q-jet.. i was just gonna get a rebuilt.. but i was able to make this one work so I won't have to replace it..
SSdeluxe- the brakets are from a 5th wheel setup the p.o. had.. I'm giving those back.. and it is 2wd.. I dont like the look of lowered or stock height longbeds.. so I'm just goin to replace the stock springs with 1tons and block the rear.. the stock susp is sagging so much that it has that raked look...
Old 10-29-2010, 07:39 PM   #13
lsp1369
Old 10-30-2010, 05:11 PM   #14
79gmcclassic
79gmcclassic's Avatar
2 wheel drives arent meant to lifted.
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 10-30-2010, 09:36 PM   #15
lsp1369
then dont lift yours
Old 10-30-2010, 09:46 PM   #16
irishman999
irishman999's Avatar
Hahaha.
I dig that green and white.
irishman999 is offline   Reply With Quote
Old 10-31-2010, 12:48 PM   #17
RandyP
Getting Old; Going Broke
RandyP's Avatar
I like the color on it as well for some odd reason, it snaps well in my opinion. The original red would look good as well though, just a matter of opinion on what you want.
I put heavy duty springs on the front of my 1/2 ton LWB, brought the front end up level with the rear. I like the look of it going "up" rather than bringing the rear down, again just personal choice though. My '74 I will be bringing down, a first for everything I suppose.
In the end, the only persons opinion that really matters is yours.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 10-31-2010, 02:05 PM   #18
81c10
81c10's Avatar
I just bought an 81 C10 swb 2wd...Theres really no point to lift a truck thats 2wd. 2wd are meant to be either left alone or dropped an inch or 2. If you lift it you'll wanna drive like its a 4wd and that could be bad...I agree with the majority of this forum. Leave the color. just polish it up a little. It looks like you need to work on the motor before you even think about touching the paint. I have a 350 with a Q-jet with electronic choke and it runs great. Just put a 2.75 x 14" K&N on there and it runs even better. I also suggest the open element.
81c10 is offline   Reply With Quote
Old 10-31-2010, 02:37 PM   #19
mooseknuckles
mooseknuckles's Avatar
cool truck......welcome to the best website ever!
mooseknuckles is offline   Reply With Quote
Old 10-31-2010, 02:49 PM   #20
nicksta43
I lifted my 86 2wd 6" 3" body and 3" suspension running 35's. I really loved the look but had no use for 4wd. Know hate body lifts because of that truck and would never use one again but it acheivd my goals and looked killer after I raised the front bumper to match. I say do it and don't worry bout the people that don't get it.
nicksta43 is offline   Reply With Quote
Old 10-31-2010, 09:17 PM   #21
lsp1369
i understand where everyone is coming from as far as lifting a 2wd truck.. but if u think that just because its a 2wd truck it wont ever be going off road, or even carrying a heavy load.. think again.. its nice to have a little ground clearane in alot of situations.. this isnt going to be a show truck by any means.. it will be a mostly a daily driver and for hauling things around... if i was going to do a nice show truck then yea it would be either stock height or lowered a bit.. but anyone who has ever owned a truck should know that they were meant to be functional.. so sorry if u dont like that i want a little ground clearance on my truck, but again.. if you dont want to lift your 2wd then dont..
to each his own...
Old 10-31-2010, 09:49 PM   #22
munice
regular everyday normal guy
munice's Avatar
to each his own...
amen! that has always been my preference.. I used to work at a place that had a 92 GMC 3/4t 2wd, and it sat really high. I always thought it looked killer, and really 2wds for the most had are far more practical as they are so much cheaper to maintain The reason I bought a 4x4 was for all the snow we get around here.. Nice truck by the way, my vote for paint would be to reverse the 2 tone with the white upper cap
-Andrew-
1987 Chevrolet V10 SM465 NP208
w/ '89 454 dual plane hi-rise 750cfm 1407
w/ '86 10b /14b
new motor on the way:
GM#990 heads
25cc speed pro pistons
COMP XE 274h
crane gold rollers
munice is offline   Reply With Quote
Old 10-31-2010, 11:59 PM   #23
lsp1369
yea.. i think im gonna go ahead and update the original color. I really like the new gm red jewel tintcoat which is kind of a metallic maroon and i think im gonna end up going that route in the future. but for now im just going to sand down to the original paint and primer over it..
Old 11-01-2010, 09:55 AM   #24
jchav62
1962 C-10
jchav62's Avatar
Welcome from Santa Fe, NM. Cool truck. I am also a fan of that green. My '73 was originally that color as well. I changed it, but later on it grew on me. I may go back one day. Also, was that truck originally a 454 truck? I see it has the emblem on the grille.
Can't wait to see what you do with it.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-01-2010, 09:59 AM   #25
justpball
justpball's Avatar
welcome bro! i dig the color also...very nice find!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
