Old 11-01-2010, 08:50 AM   #1
F-85
Shifter correction kit for 77 c10 with 700r4
What do you guys use? Its a column shift truck.
F-85 is offline   Reply With Quote
Old 11-01-2010, 10:11 AM   #2
donut
donut's Avatar
Re: Shifter correction kit for 77 c10 with 700r4
Not sure what your looking for exactly My tbh 350, I just adjust the linkage.
Course I'm not to savvy with the 700r4, maybe I'll learn too.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-01-2010, 05:58 PM   #3
HOGDADDY
HOGDADDY's Avatar
This one is for Eddy carbs
http://www.summitracing.com/parts/SUM-700203/
and this for Holley's
http://www.summitracing.com/parts/SUM-700202/
and I use one of these along with a G.M. 87 throttle cable for 700r4 trans. works perfect but I did add some xtra holes in bracket to get it closer to carb. for trans. cable. It was probably un-necessary I don't remember.
http://www.summitracing.com/parts/EDL-8036/
HOGDADDY is offline   Reply With Quote
Old 11-01-2010, 07:20 PM   #4
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
http://www.classicperform.com/NewProducts/Misc/Misc.htm
CPTSL linkage kit from CPP. Installed one on an 86swb and it works nicely!
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 11-02-2010, 10:38 PM   #5
F-85
Well to make the column shifter shift smoothly. And also an indicator showing all the gears. I looked at shiftworks and they sell an adjustable bracket to help fine tune the locations. But no indicator for the pickup trucks.
Old 11-02-2010, 10:42 PM   #6
Jonboy
Slots go on anything!
I used the shift indicator out of a later model truck, it is held to the cluster with two screws. You can loosen the bolt at the bottom of the shift linkage to adjust it. I didn't really worry too terribly much about it, as I rarely ever needed to hold first gear.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-03-2010, 11:40 AM   #7
F-85
Cool thanks.
Old 11-04-2010, 02:37 PM   #8
F-85
What year did you use? I see classic parts has them. But sells an 83-84 and a 85-87.
Old 11-04-2010, 02:47 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
On my 84, I just changed out the plastic indicator and made an adjustment of the lever to the linkage and away we went. worked fine, until I got tired of the column shifter and went to a floor shifter. That way I could not hit reverse at 60 MPH.
Frank
piecesparts is offline   Reply With Quote
