11-01-2010, 03:13 PM | #1 |
How do I stop 700R Transmission from leaking at tail end
I have replaced the rear bearing and seals in my 700R Transmission, by the next weekend its again. could it be the wrong drive shaft yoke because there is a little play after installing new tail shaft bearing?
11-01-2010, 03:59 PM | #2 |
Getting Old; Going Broke
Re: How do I stop 700R Transmission from leaking at tail end
Mines the same way, drives me nuts having a leak like that. I'm at the point where I'm just going to wait and have it rebuilt once it starts slipping a bit more.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
11-01-2010, 04:48 PM | #3 |
Slots go on anything!
Pull the driveshaft out, and put a small piece of cardboard in the end of the yoke, small enough that it will stay in the end of the yoke. The tailshaft is leaking out of the hole in the output shaft. The cardboard will help stop the leak.
1974 Jimmy- 5.3/4L80e/NP241 |
11-01-2010, 09:16 PM | #4 |
BMW & ASE Master Certified
just wondering.... but is it over filled? is that why it leaks out of the output shaft? Whats the purpose of having a hole in the yoke?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-02-2010, 10:23 AM | #5 |
Insert Witty Text Here
Could this be your problem?
http://73-87.com/7387garage/drivetrain/yokeleak.htm I had the same problem with my TH350C. I fixed it tempoaraily by cleaning the hole with brake cleaner, then using the tip of a screwdriver to dab some RTV on it. Later on, I bought the correct o-rings for it, and the problem, went away. Slonaker |
11-02-2010, 02:18 PM | #6 |
Weld the hole in the yoke shut.
11-02-2010, 02:51 PM | #7 |
thats what i did on my t350 i just welded the hole shut
Drive It Like Ya Stole It '82 Primer White c10 2wd LWB 350 sbc t350 (Hot Rod) '90 2wd LWB Silverado 350 tbi 700R4 (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
11-02-2010, 03:30 PM | #8 |
You can put axle grease on the splines to slow it down. If you close the hole it will cause the suction in the yoke and not allow it to move freely. The hole is there to vent the air between the output shaft and yoke.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
11-02-2010, 07:45 PM | #9 |
Output shaft o-ring. Trans shop should have them laying around. About a 5 minute fix.
11-03-2010, 04:22 AM | #10 |
Salty Sailor
x2
86 c-10 Custom Deluxe Savannah, Georgia |
11-03-2010, 06:48 AM | #11 |
Sometimes they just don't seal. And you need to weld it shut.
